Insert Time But Ignore Some Clips/Tracks?
Anyone know if it's possible to lock certain clips from insert/cut time?
I always assumed either the edit/time lock function did this but doesn't see to work for me |
Re: Insert Time But Ignore Some Clips/Tracks?
Hmmm, I'm not aware of a way to do this. What's the end goal here? Maybe Insert Time is not the right tool? In any case, its pretty easy to move a few clips afterwards. In all the times I have used this function, I haven't had the need to exclude anything(but of course, your needs may be different).
I think the current best way to do this is to hide the tracks you want to protect just before the Cut/Insert Time operation, then unhide them.
Here's a quick method for that: Create two memory locations — not as markers, but the kind that saves the state of visible tracks. (In the New Memory Location popup, select Time Properties > None, and General Properties > check Track Visibility). One memory location shows all tracks, and the other hides the tracks you want to protect from the Cut/Insert Time operation. Ideally these memory locations are numbers 1 and 2. You make your selection, then use the memory location shortcut to hide the tracks you want to protect (on the numpad press . then 1 (or whichever memory location number you set it to be) then . again). Do the Cut/Insert Time operation, then use the shortcut for the other memory location to show the hidden tracks again. Last edited by gills; 07-26-2022 at 05:41 PM. |
Make a group with all the tracks except video and guide.
~Will |
How to move all tracks/clips at one time | pforbess | Pro Tools 10 | 4 | 07-29-2016 11:26 AM |
Drag clips from severals tracks to one same tracks | simonyeah | Post - Surround - Video | 19 | 03-04-2016 01:28 PM |
Gap time between clips | paulo m | macOS | 2 | 09-04-2013 04:38 PM |
How do I automatically insert a plugin on all tracks at the same time? | Undertones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-29-2010 01:21 AM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
