  #21
Old 11-20-2021, 04:42 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: New Mac - M1 vs Mac Pro 2019
Do not get confused here. The thing since Big Sur has been your internal storage has been split into two parts (disregarding the recovery partition here for simplicity).
The system part is read only, and when you do OS update the process updates the read only system part of your container. And then there is the data container, which as the name implies holds your read and write data.
In case the so called corruption means your read only system partition is non-bootable you may be able to recover the system without internet connection, but for a "wipe everything clean and start over install" you obviously need internet connection.
Janne
  #22
Old 11-20-2021, 04:46 PM
Ben Jenssen's Avatar
Originally Posted by JFreak View Post
Provided the internal storage AND internet connection works, then yes. The recovery partition is in nerd terms "just an EFI that gets the thing booted into recovery mode" and after that you need a way to reinstall, and with the current computers it means internet connection.
I really think you can restore from recovery partition without internet. I never did it myself, but a little googling reassures me.
  #23
Old 11-20-2021, 04:58 PM
I know about data and system volumes, on catalina, I already mentioned that.
The size of my system volume is about the same as the invisible recovery partition, so it's likely to contain files for a complete system volume restore, although os version being the original.
  #24
Old 11-20-2021, 05:16 PM
JFreak's Avatar
Do some searching about "container" and "volume".
In short...
If your "container", say 2TB, looks like it has everything, it has those two mentioned "volumes" (and the recovery partition which I always omit for the sake of keeping it simpler). And if your data corruption is in the read only system "volume", you either have luck restoring it or not, depending where the corruption happened. You do not have complete system image on the restore partition, and whenever you need it you need internet connection.
Janne
  #25
Old 11-20-2021, 05:20 PM
Let's stop.
We've derailed the thread.
  #26
Old 11-20-2021, 05:37 PM
JFreak's Avatar
Originally Posted by Ben Jenssen View Post
Let's stop.
Well done. Ttis is still good solid info for someone interested. I have only done one clean install of M1 computer, but needed internet for it. Skål and then sleep
Janne
  #27
Old 11-20-2021, 05:40 PM
Skål for Kongen.
  #28
Old 11-25-2021, 12:50 AM
stargazer stargazer is offline
I’ve started looking for a 2019 MP.
Found one with a AMD Radeon Pro Vega II 32 GB graphics card.
I guess it’s overkill for me, syncing the occasional lo-res video.
Do you think I (or my CPU) would benefit from the extra power/features in some other way?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
  #29
Old 11-25-2021, 01:53 AM
dominicperry dominicperry is offline
The Pro Vega II is overkill but it does have a lot of TB ports - four.
The only downsides are (1) it takes up 4 slots so if you have a lot of cards (UAD, HDX) you've limited how much space you have left and (2) it will burn more power even at idle than a smaller card.
Most machines came with an Apple 580X MPX which is 1 slot and more than adequate for 3 big screens for audio applications. It has 2 TB ports. Many of these were sold off on ebay for $200-$300.
The Apple 5700X MPX is probably the sweet spot for price vs performance - 4 slots, 4 TB ports, lowish power drain. But $1000 new from Apple.
Selling the Pro Vega II will probably get you $1000-$1200 so you haven't gained much by replacing it with a 5700X.
If the machine has the right CPU for you (12-16 cores is the sweet spot really unless you are doing mental orchestral stuff) and the right amount of RAM and SSD, and is the right price, then the Pro Vega II is neither here nor there. You can swap it for a 580X at some future point and sell off the Pro Vega II if you need the cash.
  #30
Old 11-25-2021, 02:02 AM
Thanks a lot, that’s very good to know!
Actually, I’m doing orchestral work, but also use a slave Windows machine, so hopefully 16 cores will be more than enough.
Drive not seen in 2019.12, seen with 2019.6 Cryos Pro Tools 2019 0 05-30-2020 06:29 AM
HDX Ultimate - 2019.10 7 2019.12 - video export issues anguswoodhead Post - Surround - Video 2 03-09-2020 02:33 AM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
