Old 01-08-2020, 09:14 PM
thelambliesdown thelambliesdown is offline
Default APFS or Extended Journaled for session drive?
I just got done installing 2 ssds on pcie cards...
I have installed Mojave on the 250gb SSD (which will run PT) and I am ready to format the second 500gb SSD (which will be dedicated to session/audio and plug ins/samples)...
Obviously there is no choice but to have APFS on the system drive due to mojave , but what would be the best choice of format type for the session drive? Best to have both be APFS since the system drive uses it?
I already know about incompatibility for sessions for others not using APFS if they open my sessions but what else is there to worry about?
Thanks
Old 01-08-2020, 09:42 PM
Default Re: APFS or Extended Journaled for session drive?
APFS... very robust advanced filesystem, and properly designed for Flash/SSD. Installed on hundreds of millions of devices
Old 01-08-2020, 09:53 PM
Done, thanks again sir...
Old 01-09-2020, 12:37 AM
JFreak's Avatar
JFreak JFreak is offline
Nothing. Absolutely nothing. And you can always transfer sessions on even a lowly USB stick for compatibility.
Janne
Old 01-11-2020, 02:19 PM
Oliver M Oliver M is offline
I decided to delete my comment.
Old 01-11-2020, 03:57 PM
JFreak's Avatar
That would be healthy in many occasions when I for example post very late (or drunk).
Janne
Old 01-12-2020, 03:57 PM
How much APFS experience do you have and for how long? Curious... 😉
Old 01-12-2020, 10:57 PM
JFreak's Avatar
Since they introduced it in High Sierra, and I really like it.
For example, you have 1TB storage, you can create several 1TB "partitions" in it, obviously as long as total used space stays below 1TB. This is very handy when you need to clone system drives for testing. No need to pre-determine how large the partition need to be. Only used space gets used.
Janne
Old 01-14-2020, 11:48 AM
I do this since years with Carbon Copy Cloner.
Old 01-14-2020, 11:50 AM
Besides that, how do you repair drives and partitions? DiskWarrior is a no go for APFS and how it looks like never will be.
Journaled or Extended... delaplanemusic Pro Tools TDM Systems (Mac) 5 04-14-2008 01:35 AM
Journaled Drive SteveGarman Pro Tools TDM Systems (Mac) 4 12-05-2006 01:47 AM
EXTENDED Vs JOURNALED HD FORMATS Dual Mackie Storage Subsystems 3 02-25-2005 04:41 PM
Mac OsX Extended Journaled Problem Luis Miguel Storage Subsystems 4 11-03-2004 07:21 AM
Format Extended or Extended Journaled for PT6.2.3? AAR Pro Tools TDM Systems (Mac) 3 02-06-2004 07:46 AM
