Old 04-25-2012, 01:01 PM
RokVox RokVox is offline
Default Re: 10.1.2 Update = Complete Disgust!
I keep my MBP "Vanilla". I repair Disk Permissions and Restart after every install. I Verify/Repair my System HD from the Disk Utilities app. I also run Disk Warrior and Cocktail as well. As far as Crone Scripts... I don't like to f#ck with things like that!
All I know is before 10.1.2 update, everything was Kosher. After 10.1.2 update... Disaster!
Old 04-25-2012, 01:03 PM
Originally Posted by Meads View Post
The Mixer-plugin you talk about runs on PT Native.
Sorry, but from the info I gathered, this is an AAX HDX plug-in only.
Old 04-25-2012, 01:14 PM
Originally Posted by DetroitT View Post
If you move out the .dpm like versions. (Like I did) I lost some compatibility in HD-TDM sessions.
There may be other reasons so I just put the .dpm's back.
See, this is the confusing part... I was told when I was checking out an AAX plug-in from PSP Audio (I was having some problems with their new AAX version of 608MD) that they spoke to someone @ AVID and they had told PSP that it is not good to have both the AAX and RTAS versions of these plug-ins installed (this includes AVID'S plugs as well) in the plug-ins folder.
Last edited by DigiTechSupt; 04-25-2012 at 04:42 PM. Reason: There is no reason to remove DPM plug-ins when corresponding AAX plug-ins are installed.
Old 04-25-2012, 01:16 PM
Craig F Craig F is offline
there are self repair Crone Scripts that are suppose to run nightly, weekly and, monthly
if you turn you computer off at night (as most of us do) they don't run so the self repair scripts don't run
Thank you,
Craig
Old 04-25-2012, 01:21 PM
Originally Posted by Craig F View Post
It's one installer, if you had an iLok w/ a HD licene you would be running HD no extra install
And this is confusing as well! When 10 came out, we essentially had 2 installers. One for HD/HDX and the other for Native. Now AVID has gone back to combining them (like they did with 9) and there in lies the confusion, because now I'm getting components (like this HDX only "Mixer" plug) installed and I cannot use it because I'm on a Native rig. And to have the additional components installed only leads to possible software conflicts...
  #16
Old 04-25-2012, 01:22 PM
Sorry, I thought you were talking about Me personally altering Crone Scripts.
Yes, I'm aware of this. This is why I keep my computer on 24/7.
  #17
Old 04-25-2012, 01:34 PM
Originally Posted by carlos1973 View Post
This new "update" completely crashed my entire PT! This is not acceptable. Also, I've been on hold to CUSTOMER SERVICE for over 2 hours and it appears that they've just shut off their phones because they just hung up on me and when I tried calling back it's dead silence, no ring, no prompt, NOTHING! NICE GOING AVID!
So Carlos... How did things work out for you? Did you get things fixed and your rig up & running?
As far as "I've been on hold to CUSTOMER SERVICE for over 2 hours and it appears that they've just shut off their phones because they just hung up on me and when I tried calling back it's dead silence"
Been there, done that!
I would have called after this 10.1.2 debacle but alas, I had already used up that "one" very generous phone call (sounds a lot like jail, doesn't it?) that AVID gives out when I first installed 10 and it turned out to be a bug! I was never credited (given back) that "one" phone call either!
Kudos AVID!
Last edited by DigiTechSupt; 04-26-2012 at 12:26 AM. Reason: We have asked CS to send a replacement ASC to you.
  #18
Old 04-25-2012, 04:08 PM
LaryN LaryN is offline
Definitely the worst update I have ever experienced. It seems many of the set up items (H/W Buffer, delay compensation, I/O Set up, etc) cause either immediate crashes or in the case of I/O Set up random results.
I am experiencing an inability to have my imported home bus set up stick. I can import my settings, they look correct but as soon as I close i/o set up and then immediately reopen it things randomly change in the bus mapping.
Pro Tools 10.1.2
MBox 3 Pro
Assortment of plugins including Waves 9.
I have trashed prefs, repaired permissions - the usual stuff. I am about to revert because I really need to get work done - and billed!
Laurence "larz" Nefzger
System Integration Specialist
Around Sound Productions
Last edited by DigiTechSupt; 04-27-2012 at 12:47 PM. Reason: http://duc.avid.com/showthread.php?p=1925488
  #19
Old 04-25-2012, 05:05 PM
Jesse Jackson Jesse Jackson is offline
Originally Posted by izzi63 View Post
I feel ya Jess! Hope U get things worked out!
By the way... Great work with Tyga! "Storm".... AMAZING track on every level!
All the best,
~Iz
Thanks mate...
yeh about to reinstall 10.0.1 to get some work done without crashes. This is pathetic
www.JessJackson.com
Last edited by DigiTechSupt; 04-27-2012 at 12:59 PM. Reason: http://duc.avid.com/showthread.php?p=1925489
  #20
Old 04-25-2012, 11:59 PM
My pleasure!
"yeh about to reinstall 10.0.1 to get some work done without crashes. This is pathetic"
I hear ya my friend!
Well, best of luck mate!
Keep makin' them hits!
Help with Playback Engine Settings Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 08-28-2012 07:48 AM
> Please help with PT 'playback engine' settings megahurt Pro Tools TDM Systems (Mac) 5 02-05-2011 09:35 AM
Changing the device Playback Engine uses RogerAF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-19-2010 09:19 AM
PT crashes when changing Playback Engine Will Russell Pro Tools TDM Systems (Mac) 11 12-05-2006 08:15 AM
Changing Playback Engine in 7.0 Ozzie Pro Tools TDM Systems (Mac) 3 11-11-2005 11:11 AM
