Old 10-21-2011, 02:05 PM
25ghosts 25ghosts is offline
Default Re: PT10 Language
Originally Posted by Meads View Post
2) doesn't work either. Am I doing anything wrong?
Do I have to reboot my system after I delete the .lproj folders?
Try to reboot...
It should work.... very strange...
I know investing money into a new app is BS... However, over the past years Tinktool Sys has saved my Arse MANY times
Good Luck from Hamburg
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 10-21-2011, 02:22 PM
DigiTechSupt's Avatar
Setting my system language to english does work. That's what I already did, but it isn't pleasant.
When you say 'it isn't pleasant' - can you be more specific?
Changing the Language and Text System Preference to English in the Language tab should change Pro Tools to English. You'll have to restart for changes to take effect.
If this is NOT working for you, can you tell me how each of the tabs in that System Preference panel are set, so we can try to reproduce what you're seeing? Also - are you using a standard English keyboard?
Avid Audio Tech Support
Support FAQ
Old 10-21-2011, 02:26 PM
What he means by NOT Pleasant... Is that doing it this way changes his whole OS X to English.. He runs it normally in German, I take but wants PT run in english while the rest of the OS remains German !
Old 10-21-2011, 04:00 PM
Meads Meads is offline
That's exactly the point. I don't want my OS to be english entirely.
It's great, that you try to work this out DTS. Thank you, I'm sure there is a way.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 10-22-2011, 07:31 AM
marcelkavka marcelkavka is offline
Yes!
This is really annoying for everyone outside US.
But it seems, you can switch back to german keyboard after PT start.
  #16
Old 10-24-2011, 05:15 AM
david korn david korn is offline
I thought deleting the lproj would do the trick, but apparently it's only part of the story: menus are displayed in english, but windows (system performance, etc.) are still translated. Can't find what to get rid of... Tinker Tools is an okay solution, but isn't permanent.
What's to do to keep PT in english just like it used to be. Appreciate the work put in localization, but I'm used to the old way. Trying to figure out what that translated expression refers to in the english-version Pro Tools is an extra step too many.
  #17
Old 10-24-2011, 06:14 AM
clausiii's Avatar
clausiii clausiii is offline
Default
I use PT for 12 years in english now and i so far i don't like it in german. Some entries don't fit into their spaces (f.e. In the plugin buttons on top) and some menu entries sound a bit odd to me (in my own native language - german) like "identify beat" is "Schlag identifizieren"!!! That's like using Barbelfish for translation.
I'd like to have an english PT in a german OSX! Wavelab can be set to english in a german OSX
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #18
Old 10-24-2011, 09:53 AM
gugu gugu is offline
Same here. In Cubase 6 it's just an option in the preferences.
I deleted all other languages than english and like clausiii I only get the menus in english.
At least it keeps all my quickeys shortcuts running.
But Avid please why is it only a windows only option ?......
gugu
  #19
Old 10-25-2011, 10:25 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Evergreen Audio Design Group
There is really just a misunderstanding (or mis-documentation) about how localization works on OSX.
When any application launches in OSX, it looks at the System Preferences "Language and Text" settings to see what the priority language is (English vs. German in this case). If the application supports the top priority language, it displays that language. If not, it displays the next supported priority language.
What the you need to do to run their OS or other apps in German and Pro Tools in English is…
First…
Set the System Preferences "Language and Text" to German.
Log off and log back onto their system.
Now their OS should be German.
Second…
Set the System Preferences "Language and Text" to English.
Launch Pro Tools.
Now their Pro Tools will be in English.
I expect there might be some scripts or helper apps to switch the language automatically.
Here's some more information on localization support for OS X.
http://homepage.mac.com/thgewecke/mlingos9.html
  #20
Old 10-25-2011, 10:34 AM
Originally Posted by Bob Brown View Post
Second…
Launch Pro Tools.
[/url]
That's untrue. After that, the OS and every application (like mail for example) are english, not only ProTools.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Language chek0 Pro Tools Express on Mac OS X 0 12-06-2012 08:55 PM
How do I change language? wezcountry Windows 1 07-11-2011 02:42 AM
multiple language GUI dalaware Pro Tools M-Powered (Win) 0 08-07-2010 12:47 AM
GUI language switch OS X Kid_Beluski Pro Tools SE and Essential (Mac) 0 05-25-2010 12:04 AM
About foreign language Laverne General Discussion 0 03-27-2007 08:37 PM
