Re: make a bounce on half speed..
slower than real time bounce? man, Avid can't make anyone happy....
er????
If you were to record at half speed, when you come to playback it will play twice as fast - think slow motion film : film speed = 24fps, capture at 75fps and playback at 24fps = motion slowed by 3X. capture at 75fps and playback at 75fps = normal motion. capture at 12fps (half speed) and playback at 24fps = motion sped up by 2X. Your best options are to either: 1. Use the timeshift plugin in the Varispeed mode. 2. Use Elastic Audio in the Varispeed mode. 3. Import the file into a sampler and trigger it at half speed. 4. Change the file header and import without SRC. Hope that helps. |
Carl, you're right about half-speed recording of material coming in through the converters. But the suggestion was made with respect to material that was already recorded. The person who suggested doing it that way obviously hadn't thought it through, and clearly hadn't tried it himself, because it doesn't work, as Ben pointed out. x/2*2=x.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
That's ok, I understood that,
which is what I was getting at when I said: capture at 75fps and playback at 75fps = normal motion. I probably should have added: capture at 12fps (half speed) and playback at 12fps (half speed) = normal motion. Just to hammer the point home Actually, that reminds me of a technique that Walter Murch developed. As this problem shows with regard to bussing and bouncing internally, if you play something at half speed and record it at half speed, when you play it back at normal speed it obviously plays at normal speed. What Walter Murch did was play a 7.5 IPS tape at 15 IPS over speakers in a gymnasium, and record it onto another machine running at 15 IPS. When you play the tape back at 7.5 IPS the original signal is at its original pitch, but the "space" of the gymnasium has doubled in size. Cool huh! |
#16
my question was precisely the one you're asking !! so ? possible to record in while pressing cmd and space bar button or not ?
#17
Of course. Then it plays back an octave higher in pitch and twice the speed of the source. Instant chipmunks. You might get some aliasing artifacts, though. Unless the sampling filter drops an octave on half-speed record, which seems unlikely, it would be capturing frequencies that couldn't be represented by the system on normal speed reproduction. It might be wise to feed the source through a steep 10 kHz low pass filter on the way in to clean that up.
#18
hu ? how you do that ?
can you do that thrue a bounce ? |
#19
Just hit Shift+Command+Spacebar. Try it.
?? Are we talking about the same thing? It should be obvious that it's not possible to record new material while bouncing down a mix.
#20
god...
i know how to play a selection in half speed by hitting cmd and space bar button at the same time... my question was : can you record it ? and how.. |
Can you bounce in Half speed | electronicnoise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2004 08:43 AM |
Bounce at Half Speed | torquemada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2004 01:21 PM |
Bounce to Disk at half speed? | SteveGarman | Pro Tools TDM Systems (Mac) | 3 | 07-29-2004 07:11 PM |
shortcuts for half speed +dbl speed recoring | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-09-2003 02:48 PM |
Can you bounce to disk at half speed? | LATablette | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-21-2002 08:34 PM |
