#31
Re: Worth replacing 2008 Mac Pro for upgraded 2010 Mac Pro?
why recommend an OS that Avid don't? Unless he loads an earlier version, prior to 10.13.4
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#32
This includes the Radeon 5770. You should probably think about purchasing a Metal compatible graphics card.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7. |
#33
5770 is the original Mac vid card. I don't understand support metal?. Sorry, been out of the loop, so please forgive. I also just read that the single core runs more efficient than the duo core ?, and not all software utilizes all the cores ?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
#34
Apple Insider website say this about Metal;
"In order to run the new macOS Mojave, Macs must have graphics hardware capable of supporting Metal, Apple's modern low-level, low-overhead software that provides access to graphics processing." If you plan on staying on PT9 and Lion I guess it won't matter, but if you ever intend to upgrade to the newest OS (and Pro Tools) then it is a consideration. You can always upgrade your graphics card later of course.
#35
Yes, true. I cant argue with that at all. I’m still running 12.12.6, but I’ve seen the last few releases of PT run extremely well with versions versions of 10.13. If I were setting up a new system right now, I would pick one of the 10.13 releases. But I prefer to stay on the bleeding edge. Just my 2 cents.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#36
Thanks folks, well I think I will run both computers and see how the responsiveness is between the two. I'll know right off hand if the single processor is up to par in the 2010 Mac Pro is going to cut it when I use Melodyne, when using it with my 2008, Melodyne always quits during transfer, and I have to continually transfers in sections, if the 2010 transfers the the audio without quitting, that will tell me the throughput is much better.
#37
FOUND REALLY INTRIGUING.
YOU FOLKS ARE TRULY GREAT & HELPFUL. Okay I just did something I always was frustrated with Melodyne, on my 2008 Mac Pro when transferring analyzing a track, it would always quit during transferring, and I would have to start again where it left off. WOW, I just did a track, and with many plugins in the session running already, which I never do, and always use melodyne with no other plugins so it wouldn't strain the computer. Anyhow it rendered the track (FLAWLESSLY), and with many plugins running. I'm sold !. I never saw that with my 2008. Also I just swapped the SSD driver from the 2008 and fired right up in the 2010, but on the hardware playback engine it still sees *8* cores, and not the quad core for the single processor?. Perhaps that why it takes longer to boot up ?. Should I do a clean install ? thanks again
#38
If I may ask one more question please?
Looking to snag an upgrade as recommended, X5690 CPU, not really sure which one, or are they all the same ? thanks
#39
I would recommend getting a whole kit on EBay. It comes with a tool and thermal grease, etc.
I think mine are the X5690.
#40
And make sure they are not the decapitated ones for 2008/2009 MacBook Pro. For 2010 and newer you want the ones that still have the lid on the top. If you look down at the top of the processor, it’s flat silver metal.
If the top is been removed, you will see some gold components; that’s not the right one.
2008 Harpertown quad 3.0 to 2010 Westmere quad 2.4??? | audioluche | Pro Tools HDX & HD Native Systems (Mac) | 2 | 11-15-2012 06:14 PM |
2008 Mac Pro w/ lots of ram or 2009/2010 w/ low ram? | Ross H | macOS | 6 | 08-29-2011 03:19 PM |
Mac Pro 2010 2.8 GHz Quad Core vs. 2008 2.8 GHz 8-Core | audiosf | macOS | 3 | 04-07-2011 02:27 PM |
NAB April 2010 - anything new ?? | scotsman | Pro Tools TDM Systems (Mac) | 16 | 03-09-2010 11:40 PM |
Replacing stock 9600/350 (upgraded G3/400) video card | Marco Migliari | Pro Tools TDM Systems (Mac) | 0 | 11-13-2000 06:51 AM |
