Old 08-25-2007, 02:26 PM
luken luken is offline
Default Strike Installation - Plug In/Content
I am aware that during the installation procedure you can install the Strike plug-in to your OS drive and the Strike content (dataX.BIG), to another (library), drive. My question is, on my library drive, should the Strike content be installed into the Digidesign Database folder, the Program Files folder or does it even matter?
I guess I'm used to being prompted by the install program on which drive to send things to and the program creates it's own folder.
Thank you in advance,
luken
Old 08-25-2007, 02:59 PM
cneal92's Avatar
cneal92 cneal92 is offline
Default Re: Strike Installation - Plug In/Content
It doesn't matter, although don't put it in the Digi database folder. There is a little utility, "Set Strike Content Location" that you run if necessary, which basically tells Strike where to find the data.
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: [email protected]
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 08-25-2007, 03:33 PM
It would be wise to set the Strike Content Location.
filosofem
Aaron Mulqueen - 001 HD Native
Old 08-25-2007, 06:45 PM
Thank you cneal92 and filosofem for your responses. I was aware of the Strike content utility but thought that was to be used if you installed to the OS drive and then decided to move the content elsewhere. I appreciate your help.
luken
Strike Content GTBannah Virtual Instruments 29 08-08-2012 03:12 PM
Strike Content Expansion Kris75 Virtual Instruments 10 12-02-2011 05:25 AM
Help with PT8 Installation of extra content crsuribe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-08-2009 03:03 PM
Strike Content Update 77pro Virtual Instruments 4 01-20-2008 03:15 AM
OS 9.1 installation (no Digi content) MichaelK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2001 05:16 AM
