Old 12-08-2018, 02:19 PM
sighermike sighermike is offline
Default My meters changed
Hello all,
I'm using Pro tools 12.5 and it used to be that my track meters showed the output level of that track. Now, they're showing the input level or something and I can't see how much I'm pushing out. I've right clicked on the tracks to try the different meters and nothing works. Can someone help?
Thanks,
Mike
Old 12-08-2018, 04:46 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: My meters changed
Try Options>Turn OFF Pre-Fader Metering.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-09-2018, 03:08 PM
That worked. Thank you very much.
Old 12-09-2018, 03:27 PM
The Weed's Avatar
Catches me sometimes too
SonoBus
Old 12-09-2018, 08:29 PM
Just keep a few things in mind:
1-if you are NOT metering pre-fade, then you don't know what your actual recording levels are(so you might be clipping the converter going in, but not see it).
2-balancing things by ear is better in most cases. The only time I meter post-fader is; if I am mixing many tracks that are very similar sounds(like all vocals, or all strings).
YMMV and I have nothing to gain either way, but in 14 years of Pro Tools, I have used post-fade monitoring maybe 3-4 times(though others may work the exact opposite of my methods)
Old 12-10-2018, 07:04 AM
The Weed's Avatar
Another thing to remember is that plug-ins on audio tracks are PRE-fader, so any Volume Automation you do will not be reflected in the signal going through the plug-ins. (Clip Gain and AudioSuite Gain do affect the signal going through the plug-ins.) Standard practice is to bus the audio to an Aux track and put your plug-ins there. Also a good way to use common plug-ins and their same settings on multiple tracks.
SonoBus
I/O Changed wpawley Windows 4 06-28-2015 05:06 PM
The DUC has changed Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 113 03-23-2010 08:28 AM
Changed from 6.9.3 to 7.3.1 posthuset Pro Tools TDM Systems (Mac) 2 08-25-2007 08:50 AM
Track Meters Vs. Master Meters? antiphase 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-04-2004 09:33 AM
Aux input meters vs Track meters Traveler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-04-2001 09:07 AM
