Old 11-23-2020, 08:44 AM
Mishabou Mishabou is offline
Default Quality control of LtRt
Hi all,
I need to find a good QC tool for verifying LT/RT mixes. We have the latest PT HD but would prefer some sort of cross platform plug-ins (AAX, VST, Audio Units) as we are already using Resolve to QC the picture.
Thanks,
Old 11-23-2020, 09:30 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Quality control of LtRt
Ears???
IMDB
Old 11-23-2020, 10:20 AM
What tool do you use to decode / playback the Lt Rt ?
Old 11-23-2020, 11:15 AM
Leverson Leverson is offline
Minnetonka's SurCode or Neyrinck's SoundCode are two popular plugins for Pro Tools. They will encode LtRt's but will also decode and monitor them as well.
Old 11-23-2020, 11:25 AM
Any suggestions for an automated QC of LtRt ?
We receive way too many mixes for manual QC, ideally we want to set up an automated workflow and have the mixers re verify only the rejected ones .
Thanks Leverson
Old 11-23-2020, 02:43 PM
smurfyou smurfyou is offline
Thanks Leverson
You need to listen to them to hear any steering issues. I don't know that a QC tool would know if a mix sounds "wrong" when decoded. Even a plain LoRo mix will put something in the rears. (And might sound less offensive than the LtRt).
Is anyone here still delivering LtRt mixes? The topic comes up here every once in a while. I haven't touched an encoder in years.
~Will
Old 11-24-2020, 01:22 AM
papalou papalou is offline
Most of the picture QC tools (Venera, Baton, VidChecker...) can also check some audio characteristics, but AFAIK, none are able to decode LtRt. They usually just verify loudness, silence, clicks... And can optionnally decode AC3, Dolby E or Atmos, but not LtRt.
Old 11-24-2020, 06:49 AM
quadraphonics quadraphonics is offline
Can you explain a bit how/what you want verified?
That might help us give you a better answer
Hi all,
Thanks,
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 11-25-2020, 09:28 AM
For this particular project, we are receiving DPX scans and Wav (Lt Rt) files. They come from old archive films, the original sounds could be from Mag or Optical, separate or composite print, with/without Doly A or SR.
The scan part are outsource to another post house and our job is to QC the DPX and Lt Rt. These files will later be used for broadcast (Prores/LtRt) and DCP (DPX to J2K and discrete 5.1/7.1)
At the moment, the QC is done manually, i have used Baton and Telestream, both decent but cater more to broadcast workflow, not film.
We QC from Davinci Resolve in real time, so ideally i would like to find a good VST compatible decoder that will work in Resolve. All solutions available are for PT, there's Minnetonka, but it has not been updated in years and likely not compatible with Catalina.
So the only solution so far is to use a Dolby hardware (DP562, SDU4 or CP650).
As for the actual QC, basically listening to the Lt Rt for any phase/steering issues.
Old 11-25-2020, 03:05 PM
Ah thanks for clarifying. I would be strongly tempted to use the Dolby hardware. The last one I used was DP564 I think. Does PL-II decode and takes AES/EBU input. I think the 562 and SDU4 only do PL-I with a mono surround, which maybe is OK for your use? Either way they're reliable and don't break with Mac OS changes...
I used the Minnetonka for years, both RTAS and VST. Worked great but would definitely need a test run to see if it works with Catalina.
~Will
HTML code is On
HD Omni volume control quality robertszydlo Pro Tools HDX & HD Native Systems (Mac) 5 02-04-2015 04:58 PM
Quality Control question regarding tier 2 garnoil Post - Surround - Video 4 10-31-2013 09:05 AM
Quality of MicPres in Digi 002 control surface favanuestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-24-2003 08:46 AM
Paint Quality on Control/24 J Fernandez ICON & C|24 6 01-24-2002 11:02 PM
Digi001 quality control problems.... Burton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-14-2001 01:15 PM
