Trying to revert back to ProTools 9 from ProTools 10
I am trying to revert to my pervious version of protools. I had 10 working fine on this machine, but then decided to put it on a production machine.
I need to get rid of the ProTools 10 version from my laptop, and re-install version 9. The iLok I am using is licensed for PT 9. I have run the ProTools Un-Installer, but I still get a Installation Failed message when I try to install 9. Thanks |
Re: Trying to revert back to ProTools 9 from ProTools 10
When you uninstalled 10, did you also uninstall the HD driver? That will hang things up. This is why I save a drive image before EVERY software update. That makes it brutally simple to roll back. If you don't know what imaging is all about, then you really should check it out. I keep a 2TB USB drive that holds nothing but drive images. Acronis True Image is great for Windows users(not sure on Mac's but maybe Time Machine is all you need). You might also consider buying another 10 asset, or just moving your iLok with the 10 license back and forth. Moving sessions back and forth will be a PITA due to the different file format(.pts on 9 and .ptx on 10).
So does that mean that I can't revert back to 9 and that I have an unusable ilok with authorization?
I thought about moving the iLok between the two machines, but one is a laptop and I will have it with me, so that isn't a great option. Any other thoughts? Is there a page I can download 9 from? It doesn't make any sense that I can't reinstall from the CD with the proper iLok. Thanks |
You can revert back to v9 so long as there is no 'residual' code left from the v10 un-installation.
I usually run a registry cleaner after an un-install as that is where problems can occur. In my experience, PT is finicky about having clean installs & un-installs.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
you are probably going to need to go find all the driver files and delete them manually
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Revert Back To Firmware 1.02. Possible? | PeeTee | Eleven Rack | 18 | 12-23-2011 09:27 PM |
How do I revert back to an older version of ProTools LE | andyparkin79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2010 09:35 AM |
What is the best way to revert back to 8.01? | TheBaron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-20-2010 12:57 PM |
8.0.1 Unuseable how do I revert back? | Venture Studios | Pro Tools TDM Systems (Win) | 4 | 09-11-2009 10:01 PM |
How do I revert back to 7.4.2 | PTrust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-01-2009 09:56 PM |
