Old 08-07-2020, 04:41 AM
frenchman frenchman is offline
Default Time adjuster : fine adjustment of delay
Somehow Time Adjuster does not respond to the Command key modifier for fine adjustment of the sample delay, this drives me nuts. It used to... I think ?
Level reponds ok
Is this some forgotten bug ?
thanks for any light on the subject
Mark
2013 cylinder, Mojave, 16GB ram, Latest Pro Tools Ultimate and plugins
Mark Haliday
Engineer, Mixer, Writer, Teacher
Pro Tools Ultimate HDX
Mac Pro 2013 & Chassis
Old 08-07-2020, 04:54 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Time adjuster : fine adjustment of delay
OS version?
Janne
Old 08-09-2020, 11:48 PM
Mojave, but I think that this has been going on for some time
Mark Haliday
Old 08-11-2020, 08:31 AM
Click on the numbers and enter the value you want
Old 08-11-2020, 08:56 AM
Thanks, but perhaps you missed the point. All plugins, or at least all Avid plugins obey certain rules. And one of them is that when you want to fine tune a specific parameter, you use the Command modifier.
Obviously something was forgotten on this particular plugin and it is very annoying since I use for example the time adjuster to find the right phase relationship I want between a mic and a Di on a double bass or guitar.
Beeing able to shift sloooowly the delay makes this process very efficient. Having to manually input values is a drag. I noticed this quite a while ago, but lacked the time to mention this here. And I KNOW this used to work fine a few years ago when I was recording guitar amps with a multi-miked setup
Envoyé de mon SM-G950F en utilisant Tapatalk
Mark Haliday
Old 08-11-2020, 12:43 PM
I see what you mean. I calculate by setting the sub-counter to samples, then use Tab to Transient to locate the exact start of each, then offset one by the correct number of samples(sometimes with Time Adjuster to move a track later, or with nudge if I want to move one earlier).
Old 08-11-2020, 12:49 PM
I do more or less the same but once you get the "scientific" figure, it is good to tweak the setting like one or two samples forward, one or two backwards and listen at the result. For this, fine setting would be necessary !
Mark Haliday
Old 08-11-2020, 05:32 PM
Point taken and it sounds like either a bug, or a darn good suggestion(will see if I can push it up the flagpole)
HTML code is On
Time adjuster, delay comp question necjamc Pro Tools M-Powered (Win) 10 02-01-2010 07:27 PM
Time Delay Adjuster plugin... dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-06-2009 12:50 PM
Manual Delay Compensation using Time Adjuster Plugin deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-28-2008 09:30 AM
Fine volume adjustment gbours Pro Tools TDM Systems (Mac) 3 05-02-2006 07:23 PM
How to tell the Delay (for use with time adjuster) Snarf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-12-2006 05:36 PM
