Audio files, where are they?
So I've noticed that not all my audio files are NOT in the project audio files folder. Is there something I can check off to make this happen....btw where do they go?
Thanks
Pro tools 11.3, Windows 7 Premium, Desktop i5 4670 3.4ghz 16G ram quad core |
Re: Audio files????Where are they
You haven't moved the session around from drive to drive via drag and drop have you?
If the session opens ok, then simply chose: file menu, save session copy, and click all audio files and PT will gather them all up into a new session for you. |
Also, go into preferences and check "copy files on import."
Indeed, there are several ways for a user to mess this up(trust me, I learned the hard way). 2 things I will toss out for you:
#1-whenever I import audio, no matter where it comes from, I ALWAYS move/copy it into the session folder, BEFORE I use the Import audio command.(I have had "copy files on import" checked in preferences, but still had imported audio still come up as off-line) #2-if you open a "template" session and then(once it has opened) you save it to your recording drive, this is not the way to do it. either CREATE a new session from a template(not sure what version of PT you have, so there may be stuff you are not aware of). Or, create a blank session on your recording drive, then go to File>Import session Data>point to your template session and import all the tracks(this was/is the work-around in older versions of PT that did not offer the ability to "Save as Template"(from the FILE menu)
A good habit that I need to do every time! |
usaved PT session saving unsaved audio files to audio files folder | mermermer | Pro Tools HDX & HD Native Systems (Mac) | 1 | 07-18-2012 11:50 AM |
Audio files on one FW Drive render blank audio files when copied | ridmik | Digidesign Hardware & Software | 4 | 03-30-2012 12:55 PM |
All Sessions using SDII files are missing all audio files and won't relink | bigmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-18-2009 12:54 PM |
fade files and elastic audio files in wrong place | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-14-2008 02:56 PM |
Fade Files as Audio Files in "Missing Audio" ?? | CCash | Pro Tools TDM Systems (Mac) | 6 | 05-18-2005 09:00 AM |
