Old 02-16-2019, 02:55 PM
LDS LDS is offline
Default HDX Hardware and Ableton Live
Is anyone successfully running HDX hardware with Ableton Live? For whatever reason, Ableton Live keeps periodically kicking out HDX as my chosen playback engine. It might happen once an hour, or three times in a minute and require a restart.
It may well be because I am running a much outdated Live 8 on a much more modern High Sierra install... but I figure I would check and see if anyone is running a more stable Ableton setup before I spring for an upgrade.
littledevilstudios.com.au
Pro Tools Ultimate 2018.12. OSX 10.13.6. HDX. Avid Omni. Mac Pro 5,1 12x 3.33Ghz. 64Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI Radeon HD5770.
Free Lexicon 224XL Impulse Responses
Free Sony DPS-V77 Impulse Responses
Old 02-18-2019, 06:01 PM
flavor32 flavor32 is offline
Default Re: HDX Hardware and Ableton Live
Same issues with Ableton and HDX here. This has been happening with all versions of HD drivers up to the latest 18.12.0.307 and was happening with Ableton 9 and latest 10. It is extremely frustrating to say the least. Ableton will either drop the hardware or crash altogether. I notice it often happens when I am selecting audio or midi notes, or if I hit playback too quickly after hitting stop. We had to buy UA Apollos for Ableton at another very fancy studio and could not use the HDX rig or Avid interfaces properly with Ableton. I hear people have issues using HD rigs with other DAW's as well. I assume it is the Avid driver because of this. I reaaaaally wish I could use my current Avid converters properly with Ableton and others when needed. Pro Tools software is great, but work calls for other approaches sometimes.
McKay Garner
Production/Mixing/Composition
San Francisco/Los Angeles/Web 2.0
http://www.mckaygarner.com
Old 02-19-2019, 01:19 AM
LDS LDS is offline
Thanks for the reply. At least that saves me a few hundred bucks in upgrades. I only use it for composition and writing, so I think I might just take the headphone jack out of my Mac and route it into my Omni's internal mixer. Hopefully it saves some grief!
Old 02-19-2019, 08:47 AM
That does work (mac digital out into Omni) but of course there is no audio input into Ableton unless you use HDX hardware (then issues pop up again) or you use a thunderbolt/usb type interface. I am e-mailing with Avid about this again today. Fingers crossed but dunnoo...
I may have to spring for a Quantum interface or something to use with Ableton as input via thunderbolt and lightpipe or spdif out into the Omni for monitoring, but I reaaaaally don't want to
McKay Garner
Old 02-21-2019, 08:30 AM
I have been e-mailing with Avid about this the past couple of days. They are checking with their engineers on it. I have seen other users report this issue of dropping the Avid HDX/HDN hardware with Logic as well as Ableton...maybe other DAW's have this issue using coreaudio, too. Yesterday I set up my Focusrite Clarrett into my Avid Omni for monitoring via SPDIF with clocking over the coax connects and it is solid. I'd REALLY rather use my Avid Omni and HD IO, though, because they are wired into my patchbay already and sound very nice.
I sent this to Avid today...
"An additional bit of info...I wonder if it is a memory management thing to the HD Driver or something? Sometimes if I open Ableton and am in a session with no audio or MIDI (a default blank Ableton session with HDX selected as the audio engine), then open a current work session that has audio/midi data and plug-ins on tracks, Ableton will open the new session and get disconnected from the hardware upon opening the session without even hitting playback or anything. I then have to reset the audio engine to Avid HDX. Then, when using the session, sometimes selecting audio in a region or midi notes with the cursor will disconnect Ableton from the HDX hardware and I have to reselect it. Sometimes Ableton will just freeze and I get the Mac spinning wheel. This has been true with all versions of Ableton 9-10 and all versions of the HD driver AND different Mac OS versions in the past few years. If Ableton's CPU gets past 45-50%, this is more likely to happen I think. This does not happen with my other thunderbolt or firewire audio interfaces even when CPU use is much higher. They are never disconnected by the Ableton audio engine. This makes me wonder if part of the issue is with memory to the HD driver. You used to be able to change the audio buffer size from Ableton as well and the HD driver would follow. That is no longer the case much or all of the time (I have not tested every instance but see it happening)."
McKay Garner
Old 02-21-2019, 02:39 PM
LDS LDS is offline
That is a very good point about audio inputs! Pro Tools hardware does seem pretty lousy at any kind of mid-session reconfiguration - either taking ages to implement it, or prompting for a restart of Pro Tools. It all feels a little square peg, round hole at the moment.
Hopefully the new audio engine and changes made the coming 2019 release sort it all out. A third party Digilink interface like the Focusrite Reds or Antelope stuff might be an easy solution to the problem. Coreaudio for Ableton, Digilink for Pro Tools.
playing live, ableton live best option? shabbar3 Pro Tools 9 0 07-11-2013 05:22 PM
Digi 003 as hardware control surface for Ableton Live? bentropy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-02-2011 08:11 AM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
ABLETON LIVE 4 glu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-05-2005 06:07 PM
