Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
  #31
Old 02-17-2019, 09:11 AM
killah_trakz's Avatar
killah_trakz killah_trakz is offline
Default Re: C'mon Man!!!! (Pro Tools and Hyperthreading)
Bro, protools handling of cpu is TRASH!
I made a post about it not long ago. When will they fix this is MUTE!
So use Vienna and just keep working brother.
WENT FROM HD TO M-POWERED
  #32
Old 02-17-2019, 10:49 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah regardless of how he is using what, everyone knows pt isn’t the best at utilizing HT.
It’s been historically off and on, hit and miss.
They just don’t have the time or skills to better the CPU utilization of the program.
There’s always the workarounds....ever since TDM days....
Daniel
  #33
Old 02-18-2019, 10:29 AM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by arche3 View Post
Is there some sort of apple police coming to water board you for hackintosh? Haha.
No police but you could in theory
see someone serving a subpoena
Probably not likely (unless you try to go into business selling Hackentosh's with Apple OS loaded ).. but even for personal use it is technically a breach of contract and would definitely allow Apple to bring lawsuit if they chose to do so.
Violating a contract like a EULA would usually be considered a civil breach of contract not a criminal act. (usually)
That said: in the only case law I found. Apple was able to successfully get a permanent injunction against Psystar form selling Hackentosh'es with OS loaded And in the ruling the court also found copyright infringement because Apple has three registered copyrights on it's OS. And Psystar was illegally copying and distributing said copies of the OS
here is the actual court ruling
https://c-3sux78kvnkay76x24cccx2emx78uqrgcx2etkz.g00.cnet.co m/g00/3_c-3ccc.itkz.ius_/c-3SUXKVNKAY76x24nzzvx3ax2fx2fccc.mx78uqrgc.tkzx2fvj l8x2fVyeyzgx78-870.vjl_$/$/$?i10c.ua=1&i10c.dv=4
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB........PTHDN 2018.12 on OS 10.13.6 High Sierra on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Apple 1TB HDD and PT sessions storage on Apple 2TB HDD--
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #34
Old 02-18-2019, 05:57 PM
YYR123's Avatar
In the end nobody cares what your running your hardware on as long as the Music is made.
I’ve had and made hacks that are every bit as stable as my Macs that I paid a lot more money for.....(and were less powerful)
Daniel
  #35
Old 02-18-2019, 07:30 PM
RyanC RyanC is offline
Originally Posted by Sardi View Post
You’ve totally missed my point.
FYI - I setup a Hackintosh when Tiger was the current Mac OS. Wasn’t as easy as it is now.
Point taken. It is reasonable that people who down the hackintosh road need to take more personal responsibility for their own tech support...My systems run a lot better with hyperthreading on.
I got a little swept up in the anti hack stuff, which for me their argument would be valid if apple was still making computers for creative professionals.
  #36
Old 02-18-2019, 07:34 PM
Interesting...I'm much happier without VEP since PT11. I've been running hacks that are more powerful than any mac sense then as well, but I have a 12c trashcan too and it's the same for it.
For me, PT CPU handling is better than Logic, when I set up my full template in LPX, I get single core peaking issues due to auxes fed to verbs.
Which DAWs do you consider to handle CPU better than PT? I suppose it depends a lot on workflow and the computer.
  #37
Old 02-18-2019, 09:03 PM
TimNielsen TimNielsen is offline
You're clearly don't have a clue do you. A Hackintosh, legal or not, I could care less, works by you installed many 'hacked' KEXT files that make it work. You have no Apple bios. It's not an orthodox solution. None of us, not one, one a REAL apple system, are having any issues even close to what you are relating.
Hence, it's YOUR SYSTEM STUPID. If you want to run a Hackintosh, fine, I could care less. But stop pretending you're running an 'Apple' system, you're not. You're running HACKED CODE to make it work on your PC hardware. Fine, so be it. I built a Hackintosh as well years ago, actually two of them. It was so buggy and had so many issues anytime you wanted to update the software, I gave up on it.
But don't sit here, and tell us, the ENTIRE DUC, that you know more than us. Honestly, we have no idea why Vienna runs your plugins and PT doesn't. PT code for sure is behind the times.
But your problems have nothing to do with Hyperthreading. They just don't. My current mix session is running about 650+ tracks, about 150 live plugins, and I haven't had any issues. So even though you hate to hear it, the problem is you.
Originally Posted by roboman01 View Post
You heroes know nothing!!! I have 2 MacBook Pros, one 15" and one 17"...Because I built my own Mac Pro you are saying its not legal? If this is the case then why does Apple allow installation of OS X on any supported hardware? Apple hardware is nothing more than the regular PC people have at home, Apple just puts their "Apple Logo" on it and say "Hey look we have our own product" but inside the case is a Gigabyte motherboard, Intel Processor and Corsair memory. Think of it like this, HP sells computers with Microsoft pre-installed, so does that mean I cannot install Linux on that computer? What Apple did was take an OS and try to make it their own and Apple knows in COURT they would lose the argument of people installing that OS onto any system. What the courts have decided in the past was people cannot SELL them but the court said people can install OS X onto any PC they choose because if they couldn't it would be a monopoly since Apple opened up on using Intel Processors. Trust me I know more about this than most of you do, I've been building these machines since I think it was around 2006. I've built over a 1,000 PCs, dozens of servers (mickey softs) and a few OS X Servers. Now I am not saying I know everything because I don't but don't sit here and belittle people because they choose to buy OS X and install it on the same hardware that Apple uses. I buy everything, I don't pirate nothing and I surely don't steal like some of you on here do. I've paid over $5k for the software I have from originally purchasing Pro Tools, then the upgrade now the monthly subscription. I've purchased Akai Pro Studio only to be thwarted by Akai on the current "Aka Software" to force people to buy the upgrade. I've paid what close to $500 for Omnisphere 2 then the $400 for Keyscape, thousands of dollars for ReFX and their expansions, approx $4k for my Korg Kronos X and thousands of dollars for the expansions.
So trust me I know a lot more than you think. But nobody has answered why whenever I load a plugin into Pro Tools 2018 I get dropouts but if I load VEP5 then load the plugin that way its fine, no issues at all. And please do not say its my hardware because its not. Its most likely something software side and it could be within OS X itself. So, I have install High Sierra on one of my other SSDs, which I have 10 HDDs, 4 which are SSDs and all operating systems are installed on the SSDs. I will test that out to see if it makes a difference.
I've never complained about Pro Tools except their subscription stunt so now I complain something legit and boom I get hammered for it. So the way I see it, no wonder a lot of people don't come on here because of people like some of ya who are arrogant and selfish.
Yes I Googled and EVERY single link pointing to the forums the MODERATOR always says "Turn off HT"....Its 2019 and when MODs are telling people to turn of HT that shows me Pro Tools is not setup for HT like every other DAW is. You show me one other DAW besides Pro Tools that is not setup for HT I will shut up. I have used Logic and others and they support HT perfectly.
EDIT:
One last thing I had no issue until this last update!!! So think about it...Geez instead of arguing with people maybe some should think of helping or giving advice. If you come in a post just to argue on what a person has installed maybe its best to just shut up and don't post at all!!! Very selfish people in this world and I mean very selfish!!!
Good day!!!
  #38
Old 02-19-2019, 12:07 AM
Emcha_audio's Avatar
Heck if you're so adamant that it's legal, go in an apple store with you hack and ask them to check it out for you.
We'll await a video of the response of the apple tech.
EDIT:
Good day!!!
Manny.
#BOYCOTTTUSPRODUCTS
just not Pro tools and compatible plugins...
  #39
Old 02-19-2019, 02:11 AM
Sardi Sardi is offline
Hahahahaha!
  #40
Old 02-19-2019, 11:20 AM
YYR123's Avatar
I don’t even take my macs to the apple store.
Most of those kids don’t even know what a kext is.....
Daniel
hyperthreading mikeyman Pro Tools 10 15 01-06-2014 02:34 PM
Does Pro Tools LE Utilize Hyperthreading in the new Mac Pro's? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-10-2009 09:15 AM
Hyperthreading thenchel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-18-2006 12:39 PM
...hyperthreading.. jrod096 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-28-2005 11:19 AM
HYPERTHREADING SUPPORT IN PRO TOOLS LE 6.7?? Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 09-08-2005 07:06 PM
