Old 02-15-2019, 01:16 PM
boombopbop boombopbop is offline
Default Pro Tools unable to reacquire the hardware
Digidesign hardware is either not installed or in use by another application" error when launching Pro Tools with a Digi 002. anyone solved this problem?
when I reboot I get the "Pro Tools hardware is either not installed or used by anther program"
no other programs are installed.
Macbook Pro 2010 10.6.8 - Pro Tools 10.3.10 with digi 002. I've eliminated the digi 002 as the problem. I have reinstalled the protools on a new hard drive and get the same results. I think it has to be a driver issue but have tried all the drivers. System worked fine for the past 2 years. Now it just started doing this... this is frustrating. I even went up to 10.7.5 with same results. Thanks in advance for the suggestions....
Old 02-18-2019, 05:06 PM
Default Re: Pro Tools unable to reacquire the hardware
Exactly how did you eliminate the 002 as the problem? Are you aware of the "power harness" issue that hits almost all 002/002R boxes? Can you verify that the 002 works on another system? The latest 003 mixer driver should be the correct driver.
Old 02-23-2019, 12:13 PM
I tried it with a digi 003 and same results...
Unable to reacquire hardware mwconn@yahoo.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-22-2019 06:50 AM
After update to 8.0.1 error "Pro Tools is unable to reacquire the hardware" NailZ Pro Tools M-Powered (Win) 1 10-28-2009 01:25 PM
"...unable To Reacquire Hardware..." Help, please!! Rooster777 Pro Tools M-Powered (Win) 2 02-27-2008 12:10 PM
unable to reacquire the hardware! "MDW" The cause crizdee Pro Tools TDM Systems (Mac) 4 01-23-2006 06:09 PM
Unable to reacquire hardware.... Mark Tandy Digidesign Hardware & Software 4 06-07-2001 03:55 PM
