Old 01-21-2019, 03:45 AM
miul68 miul68 is offline
Default Scrolling option key commands
I'm new to ProTools coming from Cubase-Logic-S1-Reaper.
Is it possible there is no key command for the scrolling option?
Not even in pro control?
I've been searching it for days and I'm starting thinking there really you have to go through the menu for a function I use any single moment!!!
Please Help.
Best
Old 01-21-2019, 10:27 AM
Default Re: Scrolling option key commands
Keyboard Maestro
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-21-2019, 11:05 AM
Pretty easy to add via System Preferences if you are on Mac.
Go to System Preferences, then to Keyboard, then to Shortcuts, then to App
Shortcuts. There you can enter your own app specific shortcuts. Click the + sign, pick Pro Tools.app for application, then for Menu Title, add one of the following:
Options->Edit Window Scrolling->No Scrolling
Options->Edit Window Scrolling->After Playback
Options->Edit Window Scrolling->Page
Options->Edit Window Scrolling->Continuous
Options->Edit Window Scrolling->Center Playhead
Then click in the Keyboard Shortcut field and perform the key command you want to use. Make sure to click Add and not hit enter, or your keyboard shortcut gets replaced with Return. Repeat for each option you want a shortcut for.
Make sure that the keystrokes you want to use are not already used, or they won't work for the old function anymore.
Also, these can get wiped out of System Prefs when you trash Pro Tools prefs, so use a utility like Peter Gate's PT Prefs app to backup and restore your prefs, when necessary.
Hope that helps!
Scott Gatteño
Old 01-21-2019, 11:34 AM
Thank you.
Kind of crazy no shortcuts for scrolling.
I will try with system preferences.
The keyboard maestro seems to be very complex and there are no video with protools I guess quickeys is easier.
I run away from reaper because I was spending half of the time programming shortcuts.....and here I am :)
Old 01-21-2019, 12:04 PM
Using the mouse wheel beats key commands for me
Old 01-21-2019, 12:53 PM
Ah, good point. I thought the OP meant for the Scrolling Options under the Options menu, but for navigating the session, scrolling the windows horizontally and vertically, zooming in and out, and zooming waveform heights, I definitely use my Kensington Trackball's scroll wheel as well.
Scott Gatteño
Old 01-21-2019, 01:30 PM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
I imagine it's not a request they've received often since people tend to pick one method and stick with it, though I agree -- 'twould be nice to quickly switch between page scrolling and no scrolling.
Old 01-21-2019, 01:52 PM
Gordon Hookailo's Avatar
Gordon Hookailo Gordon Hookailo is offline
If you use Eucon and have an iPad, you can set scrolling modes in the user soft keys area
Old 01-21-2019, 01:55 PM
I do, and I do, and I do (but tend to forget that the function is there. Doh!).
Old 01-21-2019, 11:33 PM
Oh Yes! I finally found it.
I will also set it as a shortcut as I use it a lot.
Thank you guys.
Edit Window Scrolling / Page or No Scrolling" DAW Dogg macOS 2 02-15-2012 08:17 AM
Better scrolling option coming soon to LE? Skyflash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-24-2010 04:37 PM
MP3 Option-Demo Expired-No option for aut. code desdichadisimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-10-2006 01:24 PM
Quick Help With Scrolling Option Michael Mangia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-11-2004 06:42 PM
Commands Focus: option-hyphen Rob Macomber Pro Tools TDM Systems (Mac) 4 09-30-2001 10:28 AM
