Old 01-15-2019, 05:28 AM
samari samari is offline
Default Protools crashed while recording live show
Hi there
I am using protools for recording for a long time, and I want to say that every time I am hopping that every thing will go well and I won't have any problems.
for most of the rezones it is not in my hands.
sometimes its just stop for buffer size even if the buffer its on his limit and I continue recording and it work fine and I didn't change a thing.
But 3 days ago I record and after 4 min the meters frizzed and I couldn't escape the program until I force quit the program and when I finally restart there program I record only the last 2 songs. the band was really disappointing from that and so as I. it ruins my name and I know that I did the same as always but sometimes it work fine and sometime something happen.
I have a strong computer. MacBook Pro 15' touchscreen 16gb memory. os Mojave 10.14.2 and I record on an ssd external hard drive.
I need a solution. this is my job and if I am not 100% sure that everything will work fine so what else can I do?
Old 01-15-2019, 07:09 AM
Dan IceWood Dan IceWood is offline
Default Re: Protools crashed while recording live show
What interface are you using?
Old 01-15-2019, 07:10 AM
Also Mojave might be your issue - it is not yet qualified
Old 01-15-2019, 08:53 AM
its wasn't a problem for a several shows I did.
I am recording with firewire through venue sc 48
Old 01-15-2019, 11:14 AM
xrekcor's Avatar
xrekcor xrekcor is offline
did your puter throw an error prompt when it crashed?
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 01-15-2019, 11:16 AM
no
just told me to send a message to protools
Old 01-15-2019, 12:05 PM
Top Jimmy's Avatar
For simply capturing, I would go with something much more lightweight.
https://www.waves.com/mixers-racks/t...ng-tracks-live
James Cadwallader
Old 01-15-2019, 12:34 PM
BScout BScout is offline
If this is your job, I don't know of a single professional live mix/record engineer who isn't running a second/backup recorder. That's just standard procedure for live gigs.
Outside of this, you are running a laptop and laptops have their own issues. Turn off wifi on it. Record to the internal drive not an external drive. Don't run an unqualified operating system.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 01-15-2019, 01:57 PM
I also recommend the Waves program for live tracking as Pro Tools is just too finicky. One thing that might help; set the playback buffer as high as possible(if it was at 64, that might have hurt you and is totally unneeded for live tracking). Also, if other tracking dates went fine, did this date include any plugins that were not used on previous dates? What drive were you recording to?(if its a 5400 RPM laptop drive, that could be a show-stopper).
Old 01-15-2019, 11:50 PM
for all the above
I am using a strong laptop and with no plugins and no wifi (I know all the stuff that can interrupt the recording).
when I use the waves tracks live nothing happen and everything works fine.
But this is avid forum and I have problem with protools.
I prefer recording on protools because then I mix my recording on protools which is more comfortable.
as I said. there is no 100% on a record in protools.
isn't everybody agree on that??
Recording a live show questions Diesel10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-22-2009 12:31 PM
Recording live show (suggestions) whitetar VENUE Live Sound Systems 0 01-28-2009 02:46 AM
Live show Recording ProTools Nightmare mwingerski Pro Tools TDM Systems (Mac) 26 03-31-2006 05:47 PM
Recording a Live show with Mbox spookster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-19-2004 05:52 PM
Help! Recording live show with 2 002s? Rock_Artist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-28-2003 02:11 PM
