Old 02-02-2009, 04:55 PM
FluffyPost FluffyPost is offline
Default Hot Key "Write Automation to Selection" in preview mode
whilst in "preview mode" - with "auto touch" enabled - adjusting faders pans and plug in automation - is there a hot key to "Write Automation to Selection"
Cmd+Opt+/ will write fader + pans though will not write plug in data
any clues?
Old 02-02-2009, 05:34 PM
Drew Mazurek's Avatar
Default Re: Hot Key "Write Automation to Selection" in preview mode
Press Punch Preview, then the (Write To) All button. All writing parameters will write their settings to the selection. Is this what you're looking for?
www.drewmazurek.com
Old 02-02-2009, 06:10 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
If you are going to use teh cmd+opt+/ to write automation, use "suspend" not "preview". Hit suspense, dial in all your settings, hit cmd+opt+/, then turn off suspend and move forward to the next section...hit suspend and do the whole process again for the next scene.
Old 02-02-2009, 06:27 PM
Smile Re: Hot Key "Write Automation to Selection" in preview mode
what i'm after is a hot key for that -
also - out of preview mode - suspending automation - moving faders - cmd+opt+/ and engaging automation write no data
Old 02-03-2009, 05:07 AM
Oops, I thought this was the ICON forum, my bad.
www.drewmazurek.com
Alternate for HD's "Write to selection"? Soundburst Pro Tools 10 4 02-11-2013 01:53 PM
How is "Automation Write to Stop" working in PT 10 made Pro Tools 10 1 11-17-2011 01:53 PM
Shorty for Automation "write to all" ? murks macOS 4 06-02-2011 07:42 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
HotKey or on C8 "Write Automation to Selection" FluffyPost Tips & Tricks 2 01-27-2009 06:13 PM
