Old 09-09-2017, 08:31 AM
johnnysimmen johnnysimmen is offline
Default Midi notes getting stuck and sustaining forever after playback is paused
This is happening a lot in my sessions with various VI software, its not consistent to the various software i'm using, so it's a pro tools issue.. I will try to explain what is happening.
I will pause the playback and some of my VIs will get stuck on a note and continue to play one long continuous note forever and the only way to fix it is to go and find that VI track, make the plugin inactive to stop it and then reactivate it..
It doesn't sound like that bad of a fix but I have to do this constantly and when a client is in the studio - it comes across as unprofessional and wastes valuable time. Especially when it's an annoying sound, and I get angrier every time it happens lol.
I have tried to also freeze the track temporarily and sometimes that will work. But a lot of the time, the glitch will happen inside the frozen track. ex: from say a Chorus that has midi, to another Chorus that has midi but the verse in between those chorus's don't.. so they verse ends up with this long out of tune obnoxious sustained note.
Make sense? I don't know if anyone knows why this could be happening, but also posting so that AVID knows about it and tries to sort out this problem for their next update
mac OS 10.12.5 | Pro Tools 12.8
iMac (Retina 5K, 27-inch, Late 2015) 4 GHz Intel Core i7 24 GB 1867 MHz DDR3
Old 09-09-2017, 10:49 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Midi notes getting stuck and sustaining forever after playback is paused
Yeah had exactly that issue a good few times. Happens here with some Arturia VIs. I don't find it an issue for the AIR VIs like MiniGrand or NI stuff either. Sure is a pain in the buttocks. Like you said, goes away with turning the plugin off and on. The All MIDI Notes Off doesn't help.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 09-10-2017, 04:05 AM
Stephen
This has been an issue back to at least PT10 and maybe even earlier. I don't get it as much with the Arturia synths (I have every one) but NI's Absynth is a major offender. In a number of cases I've had it happen where a sustain off message isn't seen after a previous sustain on message.
Jack
QAPLA!
Old 09-20-2017, 05:03 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Also have this problem, but only with Synapse Dune2. I'm running PT 12.8.0 HD on Windows 7 Ultimate.
Some notes get stuck, but is unstuck again when the same note is played.
Annoying.
Midi notes lagging/hanging/sustaining PyneBoxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-08-2012 07:42 PM
Help w/Midi Notes Infintitely Sustaining JustinTapp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-10-2010 02:26 PM
Notes sustaining with PT 7.4cs7 joey44 MIDI 3 07-25-2009 12:51 PM
Structure free - Notes not sustaining anymore Murt Virtual Instruments 4 05-12-2009 03:30 AM
double notes when sustaining? Sandager 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-03-2008 02:11 PM
