"Authorization Wire Exception"
A coupe of weeks ago, after I'd been running a PT session for an hour or so with no issues, I had an error message which began "Authorization Wire Exception" and then something related to not finding a valid licence on the iLok, although I was unable to take a screen shot so I can't remember the exact words.
I relaunched PT and all was well again, until today - I launched a client's session for the first time, I worked on it for 10-15 minutes and then was interrupted by a string of around 7 or 8 error messages. All began with "Authorization Wire Exception", but then there were a variety of different explanations in each error window, the last two of which were... "Pro Tools Prerelease cannot run, because an error occurred. Encrypted Channel Bad Channel ID" and "Pro Tools 11 cannot run, because an error occurred. Encrypted Channel Bad Channel ID" there were others which related to plug in licences not being found. Are these familiar to anyone? I'm thinking it's related to the iLok- do I have a defective dongle? or a bad/intermittent USB connection? When I searched "Authorization Wire Exception" there were various threads relating to issues with the iLok server, and having previously had a demo PT licence on the iLok - but none of the threads seemed to be completely resolved. Anyone else had this? Pro Tools 11.3.1HD, HD/Native PCIe, Omni interface, Mid 2010 Mac Pro 5,1, OSX 10.9.5 Many thanks Dan |
Re: "Authorization Wire Exception"
As insurance I'd get a second iLok2 and move your license assets to there. Could be an iLok issue; have you tried switching USB ports? I seem to remember that not all USB ports on MacPros are the same.
Another thought - have you disabled AppNap for PT and other things? |
Thanks musicman - So far the issue has been so intermittent that it's going to be hard to troubleshoot and narrow things down. I've moved the iLok to a different USB port - and thanks for the tip, I'll try the AppNap thing, see how it goes.
cheers Dan |
I've run into the same thing today. This morning I upgraded to PT 12 HD from PT 10 HD. After a few hours of installing updates everything seemed to be working until I had the same string of pop up windows.
"Authorization Wire Exception" "Pro Tools Prerelease cannot run because an error occurred. Encrypted Channel Bad Channel ID" "Machine Control cannot run...etc" "HEAT cannot run..etc." Clicking OK only resets the whole pop process again. I've changed ilok USB ports but no luck. Anyone know what this is? |
Sorry about that. I was making new tracks while setting up a template in PT. I don't know of a direct cause but the warning pop ups opened 5 in a row. I'd close them and they would pop up again seconds later. This went on for 5min before I restarted the machine.
After talking with an Avid support guy he mentioned it was a rare instance that is probably to do with my ilok being misread. Suggested reinstalling the license manager and changing usb ports. This hasn't happened again since yesterday, so maybe it was a random instance. I haven't seen many posts about this error message. In any case I'll get another ilok and transfer to be safe. I'm running OSX 10.8.5 with an HD Omni. PT 12.2 HD Native. The Mac Pro is a 3.3 HGz Intel Xeon 2012. |
agressive pop up: authorization wire exception | damasio | macOS | 4 | 06-18-2014 03:41 PM |
"Fatal exception has occurred. Pro Tools must exist" | Mattlewis | Windows | 3 | 07-25-2013 10:48 AM |
"floating point exception" in thread "mainthread", at address 0x0 | simmo.d.cooper | macOS | 10 | 03-09-2013 10:34 PM |
Error 7053, "Wm exception". "TDM ProcessTypeGlues"(!) and SoundToys greyed out ! | LSNY | macOS | 1 | 02-08-2011 04:16 PM |
"uknown exception" error in protools.dll when opening an aux track | balters | Pro Tools TDM Systems (Win) | 4 | 04-06-2009 03:51 PM |
