Old 09-15-2013, 04:03 PM
jhkillam jhkillam is offline
Default "ALL" Group Shortcut Problem
Hi everyone,
I am having a weird issue with something I use rather frequently. In past versions of PT (7.4LE, 8LE, 10) I was able to press SHIFT+1 or basically like how you would type an ! and it would activate the default ALL group, allowing me to manipulate every track as one group.
Since upgrading to 11, this does not work anymore, instead it seems to bypass all plug-ins on whatever tracks are highlighted/selected (name of track with a white background).
I have tried selecting the keyboard focus button in a few different places with no avail. Other tracks that I assign letters to still respond as expected when I press their letter key to activate/deactivate them.
The shortcut still works fine when I load a session in Pro Tools 10.
Anyone use this feature at all? I have done some searching here and across google with no others reporting this problem.
Thanks for any input!
Old 09-15-2013, 04:18 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: "ALL" Group Shortcut Problem
Not sure that it's purely a Pro Tools 11 issue. Sounds like you want to be in "Group Focus" mode. This is on, by default, when you're in the mix window. If you're in the edit window, you'll need to do the following:
Group Focus Mode: Command+Option+3 (not numeric)
"ALL" Group: Shift+1
If you want to go back to Command Focus:
• Command+Option+1
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 09-15-2013, 07:56 PM
• Command+Option+1
For some reason the Group Focus keyboard shortcut doesn't work for me, but I believe you are talking about the same as clicking the AZ button in the group box.
Here is a crude video of them problem.
http://youtu.be/ydMuHmQzmwo
I enable the group focus mode, then run through the four different letters assigned to those groups, then try hitting Shift+1 and it bypasses the plugs on the VOX track that is highlighted. If I CMD+Click on the VOX track to deselect it, Shift+1 does nothing.
Old 09-15-2013, 09:17 PM
Ryan Young's Avatar
Well, looks like you're absolutely right! Sorry to have questioned you. That's a weird one that I haven't come across, yet. What happens when you're in the mix window, with group focus enabled, and shift+1?
-Ryan Young
Additional Systems
Old 09-16-2013, 05:55 AM
When I am in the mix window, the same thing happens.
On a Pro Tools shortcut website, I just found what appears to be a new addition to 11 that was not in 10. See attached photo.
Basically looks like these new plugin management shortcuts take away that <ALL> group shortcut.
Old 09-16-2013, 08:27 AM
bdangler bdangler is offline
You could use Shift+Command+G to toggle the all group on and off.
Old 09-16-2013, 05:06 PM
This disables all groups correct?
The ideal state would be I can turn on the all group when I need it with the shortcut, without affecting my other groups. When I am done with the all group, I'd like to be able to just shut it off and have my original groups still active.
Since upgrading to 11, I have just been opening that hide-away left panel that shows the active/inactive tracks and the groups to select and deselect the all group. I prefer to keep that panel closed, which is why I use the shortcuts.
I have tried changing the all group shortcut button to something other than ! (shift+1), doesn't appear to be possible, and also I figured I could create a fake all group where I just make a group that has every track, but I would have to add every new track to that group as well when I make one, which is a pain.
Any other ideas? Maybe it is something that will be adjusted in a future update, like if you are in edit or mix window command focus it will do the bypass plugin shortcut but in the group command focus it will still control the all group.
Old 02-13-2018, 11:18 AM
sjallyn sjallyn is offline
I see nothing in any newer version either and I also like to use that <all> group quick on, quick off without messing up my other group states. Anyone else find a shortcut that works to just turn that <all> group on and off without messing with anything else?
Old 06-04-2018, 01:06 PM
jimbriggs3 jimbriggs3 is offline
I'm in the same boat, y'all. Love using the All Group to make selections, but don't want it "on" all the time and don't want to leave command Keyboard Focus mode.
Any ideas?
Old 06-04-2018, 04:31 PM
The Weed's Avatar
The Weed The Weed is offline
Just leave the side bar open and click it on and off.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Midi Clips View Problem, option + "-" keyboard shortcut broken kingtinker Pro Tools 10 5 09-25-2016 01:47 PM
Pro Tools 11 always opens with the "All" group enabled? jgagne1 Pro Tools 11 6 11-08-2013 04:29 PM
Difference between "Go to Song Start" and "Return to start of session" shortcut pericoloso Pro Tools 10 2 09-22-2013 12:44 AM
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
long time problem with "duplicate" keyboard shortcut Phototropic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 10-02-2009 02:22 PM
