Loom II released!
Upgrade for a limited time - upgrade from Loom 1 for $49.99 - (and get the Tapestry Expansion for free)
- contact [email protected] to get your coupon http://www.airmusictech.com/product/...i#.WeAXuXb06po From the above link: Explore Additive Synthesis Loom II is a major upgrade to the original, pushing the boundaries of additive synthesis. Loom II is ideal for all skill levels. Whether you're starting out and just experimenting in this space or you're a bonafide expert, the instrument grows with you. Loom II is an award-winning modular additive synthesizer with a shape-shifting Morph Pad that makes it easy to create rich, swirling and captivating sounds. The original Loom was considered a triumph of its time when it was launched. Now, Loom II builds on this with unique and powerful new features as requested by our loyal users. Loom II takes a unique modular approach to additive synthesis, a synthesis technique that involves combining simple waveforms together to create complex sounds, by enabling anyone to select from and combine 34 editable modules. Create anything from wobbles, organs, ethereal pads, ambient soundscapes and so much more. The programmable Morph Pad brings your Loom II patches to life by morphing between user-defined variations of your patch, adding motion and momentum that continuously evolve. New for LOOM II: Loom II has been expanded to 8 voices by popular request! Spectral Noise section allowing a secondary oscillator to replace or enrich the additive spectrum (created with the Sine Oscillator) with a noise spectrum. This is truly revolutionary in the additive world. Your creativity is the only limit to what is possible! 4 new modules (See module section) 2 additional Subharmonic Optional Partials bellow the normal spectrum. Enhanced Morph Pad options. 500 all-new patches covering a wide range of sounds designed by acclaimed sound designers Richard Devine and Mark Ovenden. All original 350 patches re-mastered taking advantage of the new features. New Wave Parameter options 20+ other performance enhancements. Mix & Match Modules Loom II delivers up to 512 harmonic partials per patch and uses an intuitive modular design to create complex sounds quickly and easily. Each of the 34 editable modules performs a specific sonic task—Octaver, Second Tone, Moving Filter, Noise, Linear Lowpass, Modulator, etc. The Loom II framework provides a series of cells, where up to 10 of these modules can interact combine to generate an additive synthesis patch. Each module includes task-specific parameters for detailed, individual control of the patch. For real-time visual feedback of your sound, each module includes a spectrum window, offering a visual indication of how that module is affecting the individual harmonics of the sound. In Loom II we have added four new powerful modules: 5-Sines – An easy-to-use module enabling you to produce a range of organ or sine style sounds. Discrete Adder – Similar to Loom 1’s popular adder, but adding a discrete spectrum ideal for creating percussion-based synth instruments. Hype – adding Hi and Low Hype with dedicated easy-to-use controls for instant results. Double Wave – for our more advanced users: Use dual waves to create complex synth patterns. We have also added a dedicated control for this in the Morph pad. Make Your Music Move Loom II’s Morph Pad is a powerful tool that adds dynamics and movement to your patches. Using a condensed set of control knobs, Loom II enables you to quickly create up to four variations of your sound, and assign each one to different quadrant of the Morph Pad. Point, click, and drag anywhere on the Morph Pad to create a morph path. As the sound moves along this patch, you will hear it morph in real time between your four variations. This morphing can be free-form, or set to sync up to a particular musical unit—1 bar, 4 bars, etc. Plus, each segment of the morph path can be synced individually.** In Loom II, we have expanded our highly-acclaimed morph pad by allowing Points/Paths to be stored and restored separately.* We have also added a new X-Axis mode enabling it to perform like an envelope, which is ideal for rhythmical morph patterns.* For this new mode Snap/Grid is also available.* Additionally, for expanded creativity you can now use parameters not linked to the Morph. Stunning Sound Design Loom II comes packed with sounds. Acclaimed sound designers Richard Devine and Mark Ovenden have created 850+ professional, tweakable patches that include wobbles, pads, bass, soundscapes, and more.* 500 all-new presets for LOOM II and 350 re-mastered presets from LOOM I.* You can tweak, analyze, and customize their sounds to make them your own, or dig deep and begin creating your own additive sounds from scratch. For sonic inspiration, Loom II’s Smart Sound Randomizer instantly generates new parameters—or a new mix of modules—to jump-start your sound design sessions. All parameters can be mapped for MIDI control.* Additional preset packs are available free of charge and for purchase from 3rd-party partners to provide additional creativity. More than Modules Each Loom II patch begins with editable Spectral Distortion and Spectral Modulation controls that influence the overall sound. Three LFOs provide tempo syncable modulation sources that any module can access. Four velocity-sensitive Envelope Generators add an extra layer of control that can change and evolve over time. Octave control, global pitch, glide time, and other patch-specific controls offer additional tools for your custom sound-shaping experience. Expressive Effects On-board effects add extra expression to your customized additive sound creations. Using the drive or distortion on an additive sound can produce an aggressive edge or introduce rich harmonic changes. Modulation effects include a chorus and a phaser. Each adds remarkable depth and motion to your sound. Loom II also includes a reverb effect to help your sound sit in the mix, or to create an expansive audio environment.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6 Laptop + 24 BENQ GL2450-B + Samsung 27 CT550 curved Monitor * best Wife! Last edited by unkJE; 10-12-2017 at 10:49 PM. Reason: .... get the Tapestry Expansion for free |
Re: Loom II released!
Loom II videos:
Loom II Demo https://youtu.be/H92kQNCKkfQ LOOM 2 by Air Music Technology - LOOM II Tutorial, Presets, Morph & Wave Pages https://youtu.be/Exej1B_40vM LOOM 2 by Air Music Technology - LOOM II First Look, New Features, Review and Overview https://youtu.be/W4M22aVzpxI LOOM 2 by Air Music Technology - LOOM II Tutorial, Presets, Edit Page and New Features https://youtu.be/z_T41HA4oyU LOOM II - A LEGEND EVOLVED https://youtu.be/j5jempHilX4
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6 Laptop + 24 BENQ GL2450-B + Samsung 27 CT550 curved Monitor * best Wife! |
AIR long ago exhausted any chance of me giving them more money. Long outstanding acknowledged bugs in both Transfuser and Strike with no effort to fix them.
Terrible company.
Chaz Shifting Sands Audio www.shiftingsandsaudio.com soundcloud.com/shiftingsands Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
I've long given up on AIR. I still use the ones I have, but unless and until they significantly improve their customer service, as well as streamline the upgrade process itself, I see no reason to frustrate myself. There's other great VIs out there.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Suck it'n see - Trial versions available:
Mac http://www.airmusictech.com/download...c#.WeFcknb06po Windows http://www.airmusictech.com/download...C#.WeFcj3b06po
I too don't plan on updating any AiR products unless they address some issues like dragging samples in Structure 2.0, scaling GUIs, etc. I honestly prefer Logic for production and Pro Tools for mixing & mastering. I'll give Loom II a try just to see what the new modules are about and experiment with the new 8 voice limit.
Air Updates 1.0.5 Loom and Vacuum Pro | DetroitT | Virtual Instruments | 6 | 03-12-2015 10:46 AM |
Loom library? | mesaone | Virtual Instruments | 0 | 01-30-2015 09:39 AM |
AIR Vacuum Pro & Loom 50% off | Carl Kolchak | Virtual Instruments | 10 | 07-03-2013 06:16 PM |
A.I.R. releases Loom and Vacuum Pro | PatriotsBiker | Virtual Instruments | 3 | 05-11-2013 09:45 PM |
Loom labelling? | medievil | ICON & C|24 | 1 | 03-01-2004 07:21 AM |
