Unable to import .wav files
I'm on a PC PTLE platform, working with a Mac/Logic studio by
exchanging files via LaCie external drive. This has worked well until the latest session, where I had this problem: Files in various bit depths and sample rates were imported from an ADAT machine via Logic, optical connection, which created .wav files on the LaCie drive. The studio is able to open these files via the Mac with no problem. When I try to import the files to my PC via PTLE Import Audio window, I can see the files in the Files window, but when I highlight them, I see no file information in the bottom display area (Type, Length, Size, Bit Depth, etc), and neither the Add Files nor the Convert Files button works. However, I have been able to successfully import aiff files which were created in exactly the same way. I copied the .wav files to a data CD using Nero Essentials, and then tried importing them from the CD. This worked. I copied (via Windows Explorer) one of the .wav files to the same folder on the LaCie (different file name); could not import. I copied it onto my PC hard drive and was able to import the copy. I tried copying that same file back to the LaCie, and got the following message: Confirm Stream Loss The file 'Test.wav' has extra information attached to it that might be lost if you continue copying. The contents of the file will not be affected. Information that might be lost includes: Macintosh Application Info Macintosh Multimedia Resources Do you want to proceed anyway? I clicked Yes and the copy was successful, but was not able to import that copy from the LaCie. Any ideas what the problem might be? And is it possible that I am not getting a perfect digital copy when I bounce files like this? Thanks. Mike
003 Factory PT LE 7.4 Intel Core 2 CPU 6320 @ 1.86GHz Gigabyte Technology G33M-S2H 2GB DDR2-SDRAM XP Home 5.01.2600 (Service Pack 2) |
Re: Unable to import .wav files
I am assuming the LaCie is HFS+ formatted? Are you using MacDrive or some other utility on the PC to read the drive?
Tom Lynn my music: www.tomlynnmusic.com other people's music: www.headphonomenon.com |
Yes, HFS+. Pro Tools 7.3 reads this directly, no need for utility program. It comes with Digidesign HFS+ Disk Support. I know that this was installed onto my PC because I can see it listed in the control panel, add or remove programs.
Ok, so you wrote that this has worked fine until recently. My next question would be what (if anything) has changed in your workflow? Did you always go ADAT lightpipe into Logic to create your files?
It seems to me to be a file header problem. There is a difference in the way macs store information about the wav file (bit depth, sample rate, # of channels) which doesn't seem to be getting translated properly -which is why your 'file import' window sees the files but can't get any info about them. To find out why that's happening may take a bit of searching, it should be a seamless process ideally! I really don't think you need to worry about the integrity of the audio information if you use the workaround you described. Do you have wavelab or some program that offers a lot of file conversion options? Often you can open any file type and read the header details - that might tell you how the PC is 'interpreting' the file. Just a thought. Tom
Protools can be picky about wav files created by 3rd party hardware/software. I had similar problems importing files made by a Tascam MX2424, here is what cured it for me:
Find another program that reads the wav files and can save new copies of them. That will produce a fresh file with the same audio data and that program's header. Chances are Protools will accept it now. A handy tool for this is Sound Forge's Batch Converter. You can set it to convert lots of files into the same format it's already in, and it won't touch the audio data, only make fresh files that will work for you. I would use it to copy the files off DVD-RAM burned by the MX2424, takes no longer than just copying them. |
Check how the files are or were named. Delete any character other than letters. This may help.
Camilo Toledo |
Unable to import some files because QuickTime is not installed? | Mitchdeathshadow | Windows | 1 | 08-14-2013 09:29 AM |
Unable To Import .rx2 Files | ProTooler | Pro Tools TDM Systems (Mac) | 5 | 03-24-2013 04:43 AM |
Unable to import PCM files.... | tonejunkee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-10-2009 12:28 PM |
Unable to import REX or Acid files as group files in 7.4 | Luigi Lazareno | Pro Tools TDM Systems (Mac) | 2 | 03-11-2009 08:07 PM |
unable to import audio files coz quicktime missing | Redsandblu | Pro Tools TDM Systems (Mac) | 2 | 06-21-2006 01:42 AM |
