Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 05-10-2019, 08:33 AM
Gordon Hookailo's Avatar
Gordon Hookailo Gordon Hookailo is offline
Default Time lag when toggling bypass groups
My work flow depends upon being able to disable groups then re-enable them fast. In the last version of Eucon I was able to do just that with the Dock's Soft Switches under the iPad. We use an S6 in the same way. Using the Dock there is now a lag (sometimes up to 3 seconds) on Eucon 9.5. We can't work as fast we need to with that lag.
The above along with losing the ability for the S3 to remember where it's banked using Layouts slows work flow enough to consider going back to 2018.10 with an older version of Eucon.
We have just started adjusting our workflow with Eucon 9.5 and have found issues with closing Pan and Send windows as well. I'll post work arounds if I find them.
Anyone else having similar or other issues with the new Eucon? We would have stayed on the older version of Eucon but PTs 2019.5 UI gets bogged down with earlier versions.
Rig #1:
Mac Pro 5,1 12 core 3.33ghz 32gigs RAM / 10.12.6 2) SSDs, 2) RAIDS & other drives / Sonnet USB3 Card, ESATA Card / MOTU UltraLite-mk3 Hybrid firewire or HDN PCIe card 192 IO. S3 / Dock / Control Running PTs 12.61 thru 2019.5 when needed because of bugs in each version. Eucon 19.5
Rig#2
Mac Pro 3,1 8gigs RAM / 10.6.8 Pro Tools HD3 192 / 888 Running PTs 8
Old 05-10-2019, 09:15 AM
Default Re: Time lag when toggling bypass groups
Update on lag... Turns out the lag is in the indication that the groups have been suspended or not. This is on large mix sessions. Looks like the suspend toggle happens on button push just not shown on dock or in PTs right away.
Rig #1:
Rig#2
Output needs toggling every time you want to hear it - Anyone else? tj7 Pro Tools 12 15 02-11-2017 03:28 PM
Quick key for toggling time i.e. Bars|Beats & Timecode? Eric Lambert Pro Tools 11 4 04-25-2014 03:08 PM
Digi Time Adjuster bypass question clausiii Pro Tools M-Powered (Mac) 12 10-29-2013 11:04 AM
Time adjuster plug in won't bypass bukman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-31-2009 02:46 AM
Time Adjuster bug: "bypass" doesn't seem to work jmark Pro Tools M-Powered (Mac) 2 11-29-2006 11:45 AM
