Installing 003rack + with protools 12 driver error
I installed PT 12, got a firewire card for the computer, loaded latest 003 driver (9.0.8) and am getting an 'Device driver software not successfully installed' error. The interesting thing is the error message lists the device as a bunch of Chinese characters followed by 003Rack. In Device Manager it shows the device the same way - a bunch of Chinese characters003Rack. This is a Windows 7 system. I tried uninstalling/reboot/reinstalling/reboot/ plug device in, tried updating driver, tried running driver install while device is plugged in.
Any thoughts? |
Re: Installing 003rack + with protools 12 driver error
What kind of card? You need one with a TI chipset, like a SIIG.
It is a SIIG DP firewire 800 3-port PCIe, specs say it is Chipset: Texas Instruments TI XIO2213.
The 003 rack is actually a Firewire 400 unit, although most of them are backwards compatible. Maybe try re-downloading/re-extracting the driver and run it again? Did you install the driver, THEN power up the rack? (Side note: DON'T HOT-SWAP THE FIREWIRE CABLE. It fries the rack controller chip. Or as we used to say, you can't put the smoke back in.)
yes tried all combos of installing, uninstalling, removing and reinstalling. Tried older version. I don't think the problem is PT. Device Manager shows it as present but the name is a bunch of 'Chinese characters003'. It says device not installed. I am wondering if this unit is an Asian product, made for Asia, and needs an Asian driver? Such a thing?
Error message after installing mbox 2 pro driver | kyobeatz | macOS | 4 | 08-24-2014 10:52 AM |
Loading driver 2.62 get 3 errors midi keyboard and error installing driver5 | willl3 | Artist Series | 6 | 08-03-2012 04:39 PM |
003Rack+ Driver-Less, PT LE 8 | Superwoodle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-22-2012 05:48 PM |
003rack + windows7 64bit = asio driver problems | johnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-25-2011 06:28 AM |
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! | Slaido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2011 06:32 AM |
