Old 05-24-2012, 12:55 PM
MadDogRunner MadDogRunner is offline
Default Migrating to PT9 - Too many problems using PT10
I decided to start using PT9 again after experiencing way too many crashes using PT10. Now I started backing my commenced work up making use of the "Save Copy In" function as to save them in the PT9 format, and it's repeatedly giving me the problem: Could not save the ...(file as req. in...) because the system cannot find tyhe specified route.
Now, once that error appeared, I reboot the pc, try it again (using exactly the same saving parameters) and it will do it without a problem.
Now my problem is that sometimes I have to reboot the system 2 or 3 times before it does that correctly.
Could maybe Avid answer it's users in regards to these ferquent problems that are ocurring to Pro Tools 10? It would be something.
[PS: Chances of this being the very last time I purchase an Avid product and chances that I will not recommend this as a good option to audio sequencing are rising with every day that passes without Avid reacting to these issues]
Glitch problems with PT10.3 Mykul0rr Windows 11 12-07-2012 03:34 AM
002 PT8 Le move up to PT10 asking for problems? Trainwreckmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-28-2012 07:40 PM
Migrating from PT 9.x on a WXP System to new W7 System to allow for upgrade to PT10? SchweineMeister Pro Tools 10 14 03-08-2012 10:02 PM
VST Problems in PT10 hbhunt macOS 3 12-30-2011 08:14 PM
OT: TL Space-Problems in PT10 HD! lownotesinc Pro Tools TDM Systems (Mac) 1 11-07-2011 11:22 PM
