Old 06-03-2007, 07:19 PM
14choirs 14choirs is offline
Default Studiologic SL-990XP 88-Note Weighted MIDI Controller
What do you think about this Keyboard controler?
This one
I like the price and the 88-Note weihted.
Thank you for your input.
Old 06-05-2007, 07:31 PM
Chri Chri is offline
Default Re: Studiologic SL-990XP 88-Note Weighted MIDI Controller
To be honest, I lack the experience of many different models, so I am not able to base any comment on a comparison of different Master Keyboards.
But I just wanted to tell you that I am using a Fatar Studio 1100 (I think this is an previous model by Fatar) since a couple of years and I am quite happy with it.
I use it a lot for piano sounds, but also for drum patterns or pads.
But having seen all those "smart knob" controllers in Digi's new Virtual Instruments I think a modern Master Keyboard should also feature some hardware knobs to control them.
Old 06-06-2007, 08:31 AM
Brent1515 Brent1515 is offline
Yes... the Studiologic has very few MIDI controller functions. This may or may not be a disappointment depending on what ya need to use the controller for. Live... or basic synth contol, this would be fine. But if the goal is to control virtual instruments, this probably isn't the way to go IMHO. The first time you wanna assign a knob, fader or switch... or even control PT's transport via the controller, this keyboard has no such capability.
If this is important, might check out the M-Audio Keystation Pro 88 as that may be priced right too. The weighted action is a bit on the clunky side and does not transmit after touch via keyboard. But has no want for assignable/physical MIDI controller functions.
Brent
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 02:23 PM
AKAI Please Help! Note Repeat on MPD26 USB/MIDI Pad Controller derJ Pro Tools 10 2 11-10-2011 02:03 PM
MIDI Controller Data does not follow note Edit HELP Please! Crush 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-04-2011 08:55 PM
MIDI Controller Data does not follow note Edit HELP Please! Crush MIDI 13 06-03-2011 12:56 PM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 08:32 PM
