Old 07-11-2019, 11:03 AM
minister's Avatar
minister minister is offline
Default Re: Pro Tools playing back wrong video file?
Originally Posted by nhaudio View Post
Can someone please convince MPEG Streamclip's creator's to make a 64-bit version? That little app is rock solid, even if it is slow.
Use this instead:
https://www.divergentmedia.com/editready
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 07-12-2019, 07:39 AM
nhaudio nhaudio is offline
@minister: thanks... looks interesting. Is it fully 64-bit?
DaVinci Resolve also worked great and is much faster than MPEG Streamclip... only downside I can find is that it's a big piece of software for such a basic task. Although, it does allow me to experiment with Fairlight if I want... and it's free!
The developer of ff-Works was incredibly quick to reply to my questions about the issue, but didn't have a solution. Because it's just a GUI app that uses the ffmpeg framework, they seem to think it could be something wrong in the version of ffmpeg I'm using. Haven't had a chance to dig deeper on that yet.
Old 07-12-2019, 09:13 AM
minister's Avatar
Yes! It's way faster than MPEG Stremclip, Media Encoder, FFMPEG, Compressor. And you can batch! And it's cheap!
Tom Hambleton CAS
IMDb
-Starcrash
Old 07-07-2021, 07:19 AM
monter monter is offline
Yeah, I got the same problem since PT 2018 version (in earlier PT 10 there were no such problem).
I guess I found the problem in conversion using ffmpeg.
My solution is to add -metadata parameter with creation date.
For example:
Code:
ffmpeg -i INPUT.MOV -vcodec dnxhd -s 1920x1080 -b:v 36M -pix_fmt yuv422p -c:a pcm_s16be -ar 48000 -movflags use_metadata_tags -metadata Creation_Time="UTC 2021-07-07 14:09:26" OUTPUT.MOV
Look at the attachement - I used MediaInfo to check if it worked.
Let me know if this modification works for you.
P.S. You can for example modificate Marco Bernardo script (MB_Convert2DNxHD).
Old 07-07-2021, 05:47 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
I used to have this exact problem for years on my mac across multiple PT versions.
I haven't encountered it since going to PC.
It just wouldn't change video tracks, like it was stuck in some sort of hard cache with the original video. I had to restart every time, total PITA.
I also had the odd occasion where it wouldn't playback a video file unless I trimmed a few frames off the start.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
HTML code is On
Pro Tools 11 playing video back way too fast asaffulks Pro Tools 11 6 09-13-2013 06:41 AM
Playing back at wrong speed budinski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-2010 08:05 PM
Session playing back at the wrong speed ultrajoebot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-01-2008 08:06 AM
Playing back wrong files? QuickPuppy Pro Tools TDM Systems (Mac) 1 04-18-2001 04:01 PM
Playing back wrong files PTLance Pro Tools TDM Systems (Mac) 5 04-03-2001 08:51 PM
