Old 07-27-2013, 08:02 AM
asterix2k10 asterix2k10 is offline
Default Re: Video Engine won't load in PT11?
Originally Posted by Chief Technician View Post
Did you ever have Symphony or Media Composer installed? This is important to know.
I don't think so. Not seeing any related files in my Library folder or any running processes that look like it. I never installed either of those on this computer in the past.
Old 07-27-2013, 08:25 AM
Arrow Re: Video Engine won't load in PT11?
Alright. I was insisting on this point since some people had issues with v11 video and the cause was AMA plug-ins that were part of Media Composer or Symphony.
Having said that, maybe use Find Any File (Google it) to see if you have any AMA plug-ins installed?
What are your system specifications? Avid Video Engine requires 8 GB of RAM.
Old 07-27-2013, 08:37 AM
3.4GHz i7
12GB 1333 MHz DD3
AMD Radeon HD 6970M 2048 MB
Downloaded Find Any File. There's a folder called AMA under Application Support > Avid > AVX2_Plug-ins > AMA but it's empty. Then there is another folder called ama under Applications > Pro Tools.app > Contents > Frameworks > Video Engine > AvidVideoEngine.app > Contents > SharedSupport > AVX2_Plug-ins > ama
It contains these files:
AMADeviceMonitor.avx
AMALogger.avx
AMASampleProviderSupport.avx
MSP_AvidMXF.avx
MSP_MFX.avx
MVP_MSP_Quicktime.avx
XMLPlugin.avx
Old 07-27-2013, 12:12 PM
Question Re: Video Engine won't load in PT11?
3.4GHz i7
12GB 1333 MHz DD3
Good.
AMALogger.avx
MSP_AvidMXF.avx
MSP_MFX.avx
XMLPlugin.avx
I would leave those alone. Those are within the Pro Tools application for a reason.
If you launch the Console (/Applications/Utilities/) and look in system.log, do you see any useful entries around the time of day that you try to make this work and you get a hang?
Old 07-27-2013, 11:15 PM
I just ran PT while checking the system log. Here's what I got, from opening the app to closing it after it hangs.
Jul 27 23:17:10 Alon-Wolmans-iMac.local Pro Tools[668]: Cannot find function pointer NewPlugIn for factory C5A4CE5B-0BB8-11D8-9D75-0003939615B6 in CFBundle/CFPlugIn 0x7fe5d5ac6af0 </Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin> (bundle, not loaded)
Jul 27 23:17:11 Alon-Wolmans-iMac.local coreaudiod[187]: Disabled automatic stack shots because audio IO is active
Jul 27 23:17:11 Alon-Wolmans-iMac.local MIDIServer[671]: MIDIServer [671] starting; arch=x86_64
Jul 27 23:17:14 Alon-Wolmans-iMac.local SoftwareUpdater[675]: objc[675]: Class NSCustomButton is implemented in both /Applications/Pro Tools.app/Contents/Applications/SoftwareUpdater.app/Contents/Frameworks/DFW.framework/Versions/A/DFW and /Applications/Pro Tools.app/Contents/Applications/SoftwareUpdater.app/Contents/MacOS/SoftwareUpdater. One of the two will be used. Which one is undefined.
Jul 27 23:17:14 Alon-Wolmans-iMac.local SoftwareUpdater[675]: objc[675]: Class NSPushButton is implemented in both /Applications/Pro Tools.app/Contents/Applications/SoftwareUpdater.app/Contents/Frameworks/DFW.framework/Versions/A/DFW and /Applications/Pro Tools.app/Contents/Applications/SoftwareUpdater.app/Contents/MacOS/SoftwareUpdater. One of the two will be used. Which one is undefined.
Jul 27 23:17:14 Alon-Wolmans-iMac.local coreaudiod[187]: Enabled automatic stack shots because audio IO is inactive
Jul 27 23:17:14 Alon-Wolmans-iMac.local SoftwareUpdater[675]: objc[675]: Class NSCheckBox is implemented in both /Applications/Pro Tools.app/Contents/Applications/SoftwareUpdater.app/Contents/Frameworks/DFW.framework/Versions/A/DFW and /Applications/Pro Tools.app/Contents/Applications/SoftwareUpdater.app/Contents/MacOS/SoftwareUpdater. One of the two will be used. Which one is undefined.
Jul 27 23:17:14 Alon-Wolmans-iMac.local coreaudiod[187]: Disabled automatic stack shots because audio IO is active
Jul 27 23:17:16 Alon-Wolmans-iMac.local com.apple.SecurityServer[15]: Succeeded authorizing right 'com.alf' by client '/usr/libexec/ApplicationFirewall/Firewall' [541] for authorization created by '/usr/libexec/ApplicationFirewall/Firewall' [541] (100003,0)
Jul 27 23:17:40 Alon-Wolmans-iMac.local coreaudiod[187]: Enabled automatic stack shots because audio IO is inactive
I noticed when running PT10 HD (which works) I don't get the error regarding the DVCPROHDAudio.plugin
I tried moving this file but it hasn't fixed the problem.
  #16
Old 07-28-2013, 04:23 AM
nedd nedd is offline
Default Re: Video Engine Problems with Pro Tools 11
I think Mac Pro 2008 is not supported in Pro Tools 11? Or just the ATI video card?
  #17
Old 07-28-2013, 05:21 AM
Thumbs down Re: Video Engine Problems with Pro Tools 11
He's not using a Mac Pro 2008. That system.log capture shows he is using an iMac.
  #18
Old 07-28-2013, 06:48 AM
Could this be RAM related? I read that 16GB is recommended.
I will be installing 32GB of RAM next week, so we'll see what happens. In the mean time, I have submitted a support ticket to Avid and Apogee.
Also, I unchecked Enable GPU but this didn't help either.
  #19
Old 07-28-2013, 08:45 PM
I put in 16GB of RAM, same brand in each DIMM. No change.
  #20
Old 07-28-2013, 09:55 PM
Time for a clean install of Mountain Lion...
Pro Tools 10 Video Engine failed to initialize. GXTProductions Pro Tools 10 1 12-15-2013 12:54 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Pro Tools HD 8.01 Launching Video Engine fails? AMIEL Pro Tools TDM Systems (Mac) 3 10-25-2009 11:38 AM
Pro Tools 8 LE stalls at video engine launch Tommy Barth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2009 01:44 PM
Where's the Video Engine? admix Post - Surround - Video 4 05-02-2008 04:51 PM
