Old 02-13-2005, 07:40 PM
scar97 scar97 is offline
Default In Use By Another Application!!
Has anyone experienced this when closing out a session, minimizing the window or closing out protools le to do another task and trying to re-open it?
I have to re-start the computer to get it back to normal. I have tried turning the digi-002 off then on but it still says on the opening of pro tools that it is being used by another application.
Thanks
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Old 02-13-2005, 08:03 PM
Default Re: In Use By Another Application!!
I minimize protools and go to Wavelab and back with no issues at all. I run Wavelab out the computer soundcard and into the RCA aux inputs on the 002 so I just push the select button to change from PT to Wavelab.
A new Recording Application: Look! dr sound Pro Tools TDM Systems (Mac) 6 04-29-2010 10:06 AM
Live Application Ehvam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-03-2006 11:03 PM
When will ProTools LE be a 64-bit application? floatingpoint_32bit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-11-2006 04:14 PM
New cue sheet application for OS X SteveBorne Post - Surround - Video 3 10-10-2006 12:33 PM
DirectIO is in use by another application debmullin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-13-2005 10:33 AM
