Old 11-04-2018, 04:46 PM
Asaf Blasberg Asaf Blasberg is offline
Default Workflow for Pro Tools and 4K Video Camcorders to Avoid Drift
Hello,
I film lots of concerts using Panasonic 4K DVX200 camcorders. They all record 4K video with PCM uncompressed audio at stereo 48 kHz using the built-in mics of the camera.
Many times I get Pro Tools sessions from other venues. I then very easily create an AAF file to send to Avid Media Composer. The Avid very nicely puts each audio file in its own audio track so I have full control.
I also put my video track along with my audio track (the camera's built in mics). What happens is over time, there is drift and the audio/video go out of sync. I made sure to line them up perfectly from the beginning.
My understanding for the reason is that all devices have to be based on the same clock to avoid this issue.
Is my understanding that the Avid Sync HD box is the only hardware which can actually set the master clock based on LTC timecode (my camcorders have LTC timecode BNC connectors). I also have a Mosegear QBit timecode generator.
I realize that in the audio world, people use word clock to sync up all the audio devices, but in my case i have video camcorders and the venue's audio engineer uses Pro Tools to create the multitrack audio recording for me so obviously two different devices use two different clocks.
He gives me the audio files at 48 kHz, so the sampling rates of the laptop recording are the same as my camera.
Let me know what you suggest - obviously the Sync HD box is $2k but money isn't the problem, just want to make sure that this is the box that solves this issue. I was also told by MOTU that they can also set the master clock based on LTC timecode (it's in their manual) and quoting from the manual it says:
"When you choose the LTC clock mode setting, the audio phase lock engine in your MOTU interface resolves to the incoming time code. This ensures
that audio passing through the interface remains resolved to time code and won’t drift over time, as long as the audio is coming from other sources
that are also resolved to the same time code. This also ensures that audio recorded by DAW host software on a connected computer, or audio playing back from the DAW, will remain resolved to time code and won’t drift over time, even when restarting or cuing the source time code."
If I can use my QBit generator as the master and then *feed* the MOTU device the timecode as a slave, as well as the same for my video camcorder, in theory i should have no drift. Is this correct? I don't have the MOTU box so i haven't tested it.
Thank you very much for your help in this and sorry for the long long post :)
Sincerely,
Asaf
Old 11-05-2018, 08:08 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Workflow for Pro Tools and 4K Video Camcorders to Avoid Drift
Everyone at same frame rate?
Old 11-06-2018, 11:26 AM
Yes DetroitT, same eveything
Frame rate = 29.97 Drop
16bit
48kHz
Thanks,
Old 11-07-2018, 09:47 AM
JuelzB JuelzB is offline
Found this article quite informative on the subject: https://www.bhphotovideo.com/explora...why-it-matters
Custo Mac Pro, GA z490 vision d, i9 10850k, 64 GB Ram, RME Fireface 400, OS X 10.15.7, PT 2021.10 Ultimate
Old 11-07-2018, 09:51 AM
It is very interesting indeed! Yes, unfortunately it deals more with the video side than the audio side. My workaround for now is to just "stretch" the audio to the left to get it back in sync...
Old 11-07-2018, 10:47 AM
Maybe this could help: https://www.soundradix.com/products/...post/#features
Audio / video sync drift johnnyv Post - Surround - Video 10 11-24-2017 04:46 PM
PT 12.7.1 video sync drift problem JeremyG Pro Tools 12 5 03-08-2017 08:12 PM
Initial video drift idris Post - Surround - Video 2 12-02-2015 11:04 AM
New Pro Tools Workflow Video IntelDoc General Discussion 0 03-23-2013 11:04 PM
PT 7.4 Video drift soundfx Post - Surround - Video 9 11-29-2007 10:47 AM
