Old 03-11-2017, 01:59 AM
skinner22 skinner22 is offline
Default digidesign hd system help
I've recently purchased a set of Digidesign Avid HD Core and 2x HD Accel cards brand new in the box off of ebay. bad thing is that they are PCI and not PCI-E so i cant use them with my current Computer because the motherboard only has 1 pci slot
i wanted to build a new pc just for the HD sytem but i need to know from the members in the forum what is the best way to go as far as operations systems and pro tools versions i can use with them
Old 03-11-2017, 05:25 PM
Neil H Neil H is offline
Default Re: digidesign hd system help
My advice ditch them asap/sell them on asap if you are not already deep into ownership of an HD rig it will be a money pit with very little if any returns on the investment.
There are many good reasons why you got these cards cheap.
HD TDM is old outdated and under powered compared to whats out there on a native system.
Even if you built an incredibly powerful computer to use the cards with you would not be able to take full advantage of the computers native power because the HD cards will be a restricting factor as they will max out of voices first.
First you need a computer with native PCI slot bus support which ended some years ago now on most boards I think the only to still support it are intel B series and then you need enough PCI bandwidth to handle the cards all running at once which was a huge headache when trying to build systems for TDM use, boards with such features are hard to find if not now impossible.
Then you'll have to be running 32 bit Pro Tools and the latest version you can use is PT10 (this has to be PTHD10 not just regular native PT10 and is very expensive compared to the native version) 32bit Pro tools has a RAM limitation where it can only take advantage of a maximum 3.5GB of RAM even if you full your machine with 64GB. 3.5GB is a very small amount these days and will get eaten up very quickly with plugins and don't even think about virtual instruments!
Then there's the plugins, To take advantage of the TDM DSP chips you'll need HD TDM plugins not native, although native will work with Pro Tools you'll soon eat up your voice count bussing back and forth to native plugins and you can'y real time monitor though them on record without a TDM plugin inserted in the first slot.
If you cant find a board with enough slots and PCI bandwidth your next port of call would be a Magma expansion chassis such as P7R4 or PE6R4i which again is more investment (will cost a few hundred) Or you can buy an OLD G5 Mac that had PCI slots and will be a slow as a snail that's just been squashed.
Then you'll need an interface such as a 192io or a 96io (another few hundred) to get the audio in and out.
If not much of what I'm saying is making sense to you then you have a lot of learning ahead of you so stop right there and get rid of the cards and try to make your money back, or you can of course ignore me and prepare yourself for spending a lot of money on a lot of headaches for no more gains but quite a few more limitations to a regular Native CPU rig.
I've had several TDM systems over the years and still have one in my studio but only because i'm heavily invested in 5x cards in a magma chassis lots of TDM plugins, 4x interfaces, a Pro Control and 2 fader packs so do have plenty of experience.
If you are still dead set on using them and i haven't put you off yet, You could look for a used HPXW8400 PC which will take the cards, Run Windows 7 and Pro Tools HD 8,9 or 10 and I wish you the best of luck !
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 03-11-2017, 06:07 PM
Or buy a Magma chassis that has PCI slots, with an interface card for a PCIe slot in the new computer You will be limited to PT 10 HD though
Old 03-11-2017, 06:17 PM
I covered that
Windows 10 Pro
Old 03-11-2017, 08:12 PM
thanks. i was moving too fast on ebay and thought they where pci-e but didnt realize it until it was shipped. and i was just about to buy a 192 digital i/o
Old 03-12-2017, 06:22 AM
Many of the same issues exist for the PCIe cards too, the DSP is not all that useful these days because Native power far exceeds what the DSP can do and trying to do DSP/Native hybrid processing is a resource hog on the voice count so you still run out of power before you hit maximum CPU.
Plus you still have to buy a copy of Pro Tools HD which is expensive and harder to find used (plus ownership transfer can only be done with accompanying hardware).
Windows 10 Pro
Old 06-23-2017, 12:49 PM
Sugarnutz Sugarnutz is offline
You can always get this motherboard (if you can find one):
JetWay JNAF93-Q77 LGA 1155 Intel Q77
It has 4 PCI slots and runs HD 8.1 fine under Win 7 64 bit. Mine has an i5 and 16 Gb of RAM. A license for HD 8 is $50 on eBay. Get some 192 interfaces cheap and have at it. I clock mine from a Antelope Zen Studio plus with the mic pres out into the 192 or Omni via ADAT. I'm also looking to get another couple of 192 Digitals for feeding from separate VI computers. I've got 24-28 mic pres into mine (depends on sample rate 28 @ 44.1/48 KHz and 24 @ 88.2/96 KHz). I mix with my "Vanilla" PT listed below. All kinds of fun can be had with these things if you go in with an open mind. Have phun!
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Old 06-23-2017, 01:42 PM
YYR123's Avatar
YYR123 YYR123 is offline
As Neil said....I agree with all of it....but
If you want to go that route you have to go all In..... HD7, magma chassis, and fully commit to the old tech....it's not without its benefits (what's the spec 1.8m/s latency)
But you have to buy a bunch of gear, you can't do any real work with a HD2 or HD3 imho - max that sucker out and get HD6/7 and go all in....All TDM plugs and tons of 192's
It's a great environment to work in, but it does have its own limitations (mainly close to zero native power compared to today's standard)
But you have to ask yourself "is that what you need?"
if it fits what you need then there's nothing like it
Also the PCIE cards have more DSP power than the PCI-X cards
Daniel
Old 06-24-2017, 08:43 AM
Actually only the PCIe core card is the only card that's more powerful because they made them into accel cards.
So PCIe systems consist of an Accel Core and then Accel cards.
A PCI system consists of a non Accel Core and Accel cards.
You can also use the older non Accel PCI "process" cards that have the same DSP as a non Accel core but I wouldn't bother as it's a water of a PCl slot and most of the TDM plug inside were updated to require accel processing so a process card would be next to useless.
You also want to be careful just fully loading a system with cards because bandwidth can quickly become an issue on some motherboards I would say go with an HD5 to start with and see how that goes before investing in more cards.
Windows 10 Pro
Old 10-14-2017, 10:26 AM
ddayson ddayson is offline
Hmmm, we're running three 3.4Ghz i7 Dual Threaded Quad Core (8 cores to PT HD), PC based PCIx HD4 systems with UAD-2 Octo cards, and they work great in our experience (PT HD 8.0.5/9.x).
Fast PC's with native PCI slots are harder to find, but still out there as of a few months ago, and we used...
Motherboard:
JetWay JNAF93-Q77 LGA 1155 Intel Q77 - 4x PCI slots, 3x PCIe slots
Processor:
Intel Core i7-3770 Ivy Bridge 3.4GHz (3.9GHz Turbo) LGA 1155
Memory:
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
Power supply:
CORSAIR CX series CX750 750W ATX12V / EPS12V
Case:
Rosewill Blackbone Black Steel / Plastic ATX Mid Tower (needs some internal trimming to fit all four PCI Cards, simple with Tin Snips).
OS:
Microsoft Windows 7 Professional SP1 64-bit - OEM
The builds cost about $1K each with HD's. These PT HD systems work great and have more power than we'll ever need, and we get around the 32 bit limitation with external PC VI Host(s). TDM has low latency for tracking, and the 8 Cores in addition to the HD/UAD-2 cards is more DSP than we'll ever use for simple stereo music production.
FS: Digidesign HD3 PCI system w/192's, Sync... Goo Buy & Sell 0 03-11-2013 11:47 PM
digidesign system INI bus error goodtimes Tips & Tricks 0 07-15-2007 08:42 PM
digidesign system ini goodtimes Pro Tools TDM Systems (Mac) 0 07-04-2007 11:25 AM
Hey Digidesign! Why there's no system driver 4 XP? yuri00 General Discussion 0 09-09-2003 12:30 PM
!!!HELP DIGIDESIGN, My new HD system does not find my 192 HELP!!! Bobby Peru Pro Tools TDM Systems (Mac) 8 06-15-2002 10:13 AM
