Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-18-2021, 06:18 PM
Tryingtowork Tryingtowork is offline
Default Interface not recognized?
Question folks, I'm using a zoom Podtrak P8 as an interface and PT isn't recognizing it at all in the playback engine menu.
-I'm on Version 2020.11.0
-I have my default audio input/output in windows set to the P8
-I set the playback engine to "Default Windows Media device"
-When I record PT uses the computer mic and plays back on the computer speakers
Anyone have an idea what the problem may be?
Old 04-19-2021, 06:50 AM
sw rec sw rec is online now
Default Re: Interface not recognized?
It’s actually doing exactly what you told it to do! Make your onboard soundcard the default playback device for Windows audio. Your P8 needs to be exclusively available for PT. Pro Tools, especially on Windows, doesn’t like to share hardware.
Old 04-19-2021, 11:08 AM
The Weed's Avatar
The Weed The Weed is offline
Does the P8 have an ASIO driver? Besides leaving it exclusively for Pro Tools, on Windows, you need an ASIO driver. Alternatively, you can try ASIO4ALL, but it's a Band-Aid.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-19-2021, 11:31 AM
K Roche's Avatar
K Roche K Roche is offline
Maybe I have an idea unfortunately I am on Mac
But I am thinking you do not want the playback engine set to " Default Windows Media device" (which I am guessing is your computer, and why it is recording and playing back on the computer)
You want the playback engine set to the P8
Also from the P8 manual it looks like it will only transmit 2 channels of USB to the computer . (don't know if this is an issue for you or not)
To get the P8 to show as a "playback engine" option
(at least this is how it works on Mac) Hold the (N) key down while launching Pro Tools and while launching it should stop with a window opening asking if you want P8 as a new playback engine Or it will at least show in the playback engine button dropdown as an option ,,,, select it and PT will close ..Relaunch it and it should be the selected playback engine
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 04-22-2021, 01:04 PM
Thanks for the responses folks. Unfortunately I cannot select the p8 under playback engine because it doesn't show up. When I get back to the computer I'll try what K Roche suggested. Also when I checked zooms website it said no driver downloads necessary for the p8, sorry The Weed.
Old 04-22-2021, 04:26 PM
The Weed's Avatar
Pro Tools on Windows usually requires an ASIO driver be used. If there is no ASIO driver, try ASIO4ALL.
SonoBus
Old 04-29-2021, 12:54 PM
So thanks, but that also didn't help. What I did find out tho is that the P8 is an MME interface rather than ASIO. That option isn't even in the playback engine menu. Is there a way PT recognizes MME interfaces?
Old 04-29-2021, 04:50 PM
The Weed's Avatar
Here is some Windows driver information.
And here is some information on ASIO4ALL.
If you can't get the P8 to work with Pro Tools, try it with Reaper - it has a 60 day trial.
Realistically, if you want to work with a mainstream DAW on Windows, you need an interface with an ASIO driver.
SonoBus
interface not recognized in PT 12.5 JBtech Third Party Interfaces 5 07-28-2016 05:25 AM
C/24 with 003 interface not recognized. Acustiman ICON & C|24 2 06-11-2014 12:56 PM
Interface not recognized. chainboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-24-2011 01:38 PM
003 interface is not recognized by PT9 Shame macOS 5 01-11-2011 10:27 AM
Second Interface Not Recognized romemtech Pro Tools TDM Systems (Mac) 4 02-09-2002 01:43 AM
