Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 06-05-2019, 01:01 AM
MarcOFB MarcOFB is offline
Default Slate TB Mic System 5
Im using digital monitoring, and from what i read in the manual, i could use a TB mic by pluggin it into whatever preamp, and patching the signal into the Slate_TB in patchnet. Is it possible to route that tb signal to the A/B/C/D Monitor outs?
Old 06-20-2019, 03:44 AM
qtvaudio qtvaudio is offline
Default Re: Slate TB Mic System 5
To follow on from our chat from earlier, I tested this and found that it sums the TB mics with an oscilator tone. If that can be disabled then it could be a solution but I haven't worked out how.
Slate Trigger 2 crashing PT 19.5 on my system Neale Eckstein Pro Tools 2019 18 12-03-2019 07:37 PM
For sale: Slate vcc, slate vbc, softube trident a-range, lexicon lxp native Bubblegum Buy & Sell 4 01-10-2017 07:54 PM
Apparently, Slate Virtual Microphone System is no longer vaporware mesaone General Discussion 11 05-28-2016 08:17 PM
The Slate Virtual Microphone System (VMS) Is Here unkJE General Discussion 13 11-04-2015 04:12 PM
Slate Pro Audio RAVEN MTX Multi-Touch Production System Benoni General Discussion 77 09-17-2013 06:31 AM
