AJA Gen 10, IO XT, and sync hd
Can't seem to get this to lock. What am I doing wrong?
Sync HD loop sync in/out ----- 192 loop sync in/out Sync HD video out terminated Sync HD host serial ----- HD native card Aja Gen10 Out 1----- Sync HD video in Aja Gen10 Out 2----- LTC/Ref PT12 settings attached. Thanks for the help! |
Re: AJA Gen 10, IO XT, and sync hd
As TVPostSound said....
Also, your session is set to 23.976 FPS. You need to select a tri-level sync source option from the session setup drop-down menu. Also you need to ensure your Gen10 to exactly the same format of video reference via the dip switches on the base of the unit. |
Aja Gen10 Out 2----- NOTHING
Thanks! Where is the tri-level sync source option? Not seeing that in the session setup. That may be the missing link, as the sync HD timecode is still stuck at 00:00:00:00 |
Only the 1st dip switch on the Gen10 is engaged, set to HD.
Look at pages 8 & 9 for setting the dip switches to match your video format.
https://www.aja.com/assets/support/f...N10_v1.0r2.pdf |
Thank you
So I changed one of the switches to match the 1080p/23.98 (0 1 0 ) Still nothing! Thoughts? |
NOT VIDEO but VIDEO REF
IMDB |
Yes! Thank you! Things are looking up!
The sync HD is still at 00 and not moving. Is this an issue? |
screenshot
Sync HD reverts back to loop sync after PT quit | [email protected] | macOS | 1 | 07-23-2015 02:37 PM |
Sync Audio - Editor Used Camera Track Only -Waveform Sync? | milosziv | Post - Surround - Video | 7 | 11-30-2011 05:26 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Can Mbox sync to midi timecode or smpte sync? | greeneye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2004 08:47 AM |
Sync Processor's Tremolo to Midi Time Sync via Interface | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-01-2000 12:08 AM |
