Old 10-24-2013, 11:46 AM
TL4500 TL4500 is offline
Default DAE Error 13001
Hi.
I have just loaded Pro Tools 10 from discs onto a new Laptop with Windows 8 (64 bit). When I come to firing up Pro Tools I am getting a DAE error 13001.
I used CMD net user administrator /active:yes to "log on" as admin for the install. I downloaded the latest drivers for my M-Audio Fastrack Ultra 8R prior to install.
Anyone any ideas please. Desperate to get up and running!
Cheers,
T
Old 10-24-2013, 12:38 PM
Southsidemusic's Avatar
Default Re: DAE Error 13001
Originally Posted by TL4500 View Post
Hi.
Cheers,
T
Hey
Try these KB pages and these links. Has to do with memory allocation as far as I understand it.
http://avid.force.com/pkb/articles/e...ssage/en406391
http://avid.force.com/pkb/articles/e...%2013001&site=
http://duc.avid.com/showthread.php?t=338392
Hopefully that will help you somewhat.
Also try to disable "disk cache" under settings and see if the problem persists.
Best
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-24-2013, 12:44 PM
Thanks for that.
I looked through previous posts and found something similar. I right clicked Pro Tools to find that integrated graphics was default. I changed this to NVidia and also ran as admin. However...
I then got this error:
Could not allocate memory for the disc cache. Try lowering your disc buffer (DEA Buffer), disc cache size or engine voice count. If you got this error on launch delete your prefs and try again (-9514).
I am not a very experienced user so I don't really have a clue where to change this stuff. Any help gratefully received.
Thanks,
T
PS Pro Tools isn't opening so I can't get to the menus to change any of this?
Old 10-24-2013, 12:52 PM
In order to help you we need more info.
Read up here and post the information needed to move forward please.
http://duc.avid.com/showthread.php?t=300050
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 10-24-2013, 01:15 PM
Computer model and processor speed Lenovo with Intel i7 3612QM 2.1GHz
OS version Windows 8
Avid hardware model M-Audio Fasttrack Ultra 8R
Pro Tools version 10.0.0
Amount of RAM installed 8Gb
No other FireWire or USB devices attached
Number and type (firewire, SATA, SCSI, etc) of drives installed ST1000LM024 HN-M101MBB. Hard drive split into 3, C, D and P for ProTools recording files (nothing on it yet).
So far all I have done is what is listed above.
Is it possible to change the DAE Buffer, Disc cache etc. from outside Pro Tools or is this done only within PT from the dropdowns?
Thanks,
T
Old 10-24-2013, 01:35 PM
Thanks,
T
Hi
You need to be able to start PT in order to make the necessary changes and if no one else can jump in and help out I would reinstall everything including Windows and start at the beginning. Whats your soundcard? Have you installed the latest drivers for the soundcard (M-Audio) and the PT update version 10.3.6 or 10.3.7?
Before wiping the windows and pro tools off try Download the latest update of PT10. It will be in your Avid account and be called 10.3.7 or 10.3.6.
Try that and come back
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 10-27-2013, 02:51 AM
Hi.
Just to let you know, I downloaded 10.3.7 yesterday. When I installed it wouldn't attempt to open but I changed to compatibility mode for Windows 7 and opened as Admin and (fingers crossed) all seeks OK.
I have had a couple of error messages today:
6085 - "The audio device buffer overflowed, if this occurs frequently try decreasing the H/W buffer size........"
Q. If it overflowed should I not be increasing it?
I then got the CPU usage error a few times. I had it set at 90%. Now changed to 99%. If the error persists does this indicate the CPU may not be able to handle Pro Tools?
Thanks,
T
Dae error -13001 Rockman413 Pro Tools 10 6 07-25-2013 08:56 AM
DAE Error-13001 encountered trizzy Windows 2 05-04-2013 07:38 PM
DAE error -13001 on PT 8.0.4 for W7 astrojed Tips & Tricks 0 09-15-2012 03:16 PM
DAE error - 13001 was encountered tjavier1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-10-2009 01:25 PM
error 13001 when launching OMS visitord 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-29-2001 08:54 AM
