Help needed from Yamaha 01V96 owners
My recording setup currently consists of the Digi002 Rack, PreSonus Digimax, Focusrite ISA 110. My live setup for running sound consists of a Mackie 1604VLZ along with lots of outboard gear (compressors, gates, effects). I am considering upgrading to the Yamaha 01V96 in order to have higher quality, eliminate some outboard gear, have a control surface for ProTools, and be able to record live. It would also be nice to have more than 16 channels for live use.
From the reading I've been doing, it seems I can connect my Digimax right to the 01V96 via lightpipe and now I've got 20 channels (mic pres). Is this correct? If I needed even more channels could I buy a Behringer ADA8000, and the ADAT expansion card for the Yamaha and now have 28 channels? Do the Yammies compressors and gates work on the channels brought in through lightpipe or just the 12 built in channels? If I wanted to do a live recording of a show, what would be the best way to connect to my 002R? If I go out of the Yamaha's lightpipe into the 002R then I've got 8 channels. How do I get more channels out of the Yamaha and into the 002R? I will need the Omni outs for my monitor mixes. Could I get the ADAT expension card and send a second lightpipe signal into a Behringer ADA8000 and send the line outs into my 002R's analog inputs? That would get me to 16 tracks of live recording which would be fine. I see there is a card for the Yamaha that has 16 channels of Firewire I/O called a my16mLan. Could I somehow get this into ProTools? I am also considering Mackie's new Onyx mixer because it has an option to take the 16 channels into a PC through Firewire. As long as I can get wave files into my computer I can import them into ProTools. A bonus of getting the Yamaha is being able to use it as a control surface for PT LE. I'm used to using a mouse because I've been doing it that way for so long now, but it would be nice to have real faders again. Is the integration with PT LE pretty easy to do this? I'm torn between getting the Mackie Onyx or saving a little longer and getting the Yamaha. Any insight would be greatly appreciated. Thanks.
LANPARTY UT nF3 250GB RT Athlon 3400 DTR G.SKILL 1G(512X2) F1-3200DSU2-1GBLC ZALMAN CNPS7000B-CU RT EnerMax EG365P-VE FMA 1.3 RT GeForce2MX |
Re: Help needed from Yamaha 01V96 owners
Ok, I just called the local store I used to work at, and because I used to work there they will sell me a brand new 01V96 for $1669 which is a steal. I'm close to pulling the trigger. Could anybody help answer some of my questions so I make sure I'm not buying something that won't do what i want/need. Thanks guys!
That was very informative. Thank you!
Could you elaborate a little on how I would go about doing the live recording with the Firewire card? Does Yamaha have software that will let me record the wave files or is there something else? I currently own Vegas 4, which is a multitrack editor that I might be able to use. I wonder if the firewire inputs would show up in Vegas. I've been mixing on my 1604 VLZ for many years. Will I really notice a difference audibly going to the Yamaha? I am always upgrading my PA system and starting to get more offers for bigger shows. I think the Yamaha would be a little more rider friendly than the Mackie too. Thanks.
Lastly, will you hear a sound differance between the '96 and the 1604? Absolutely. In all fairness the 1604VLZ Mic pre's and circuit design hasn't changed all that much from the original 1604. Comparatively, the '96 sounds much 'better' than the original O1V. And the original was no slouch either. Let your ears guide you. |
Well, I appreciate the answering of my questions and the advice. I purchased it tonight and I'm about to take it out of the box. Could be a late night tonight...
Thanks for the help guys.
Using a Yamaha 01V96 with PT? | LynxAudio | Tips & Tricks | 1 | 07-22-2010 07:08 AM |
yamaha 01v96/hd1 | johnnyz | Pro Tools TDM Systems (Mac) | 0 | 04-06-2008 06:51 AM |
yamaha 01v96 and PT7.0 | sitonka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-22-2005 08:11 AM |
Anybody ever used the Yamaha 01V96?? | spookster | General Discussion | 6 | 01-15-2004 01:33 PM |
Yamaha 01V96 Yea or Nea? | Morningstar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-30-2003 03:54 PM |
