Old 10-19-2016, 01:49 PM
Scott G Scott G is offline
Default Muting just one automation parameter?
I have what seems to be a simple question but I couldn’t find the answer searching the internet. Is there a way to turn off, mute or delete just one automation parameter but leave the others intact? Can I turnoff pan automation but still reed volume automation? I sometimes get 2 tracks of identical dialog panned left and right. I would prefer to just use one of the diolog tracks and pan it to the center and keep the volume info.
Thanks
Scott
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 10-19-2016, 02:01 PM
FajitaTone FajitaTone is offline
Default Re: Muteing just one automation parameter?
Split to mono, mute one track?
Ray Trujillo
Freelance Audio Engineer
Old 10-19-2016, 04:41 PM
They are coming as 2 mono tracks. one panned left and the other panned right.
Scott
Scott
Old 10-19-2016, 05:22 PM
smurfyou smurfyou is offline
Default Re: Muting just one automation parameter?
You could try not importing Pan automation when you bring in the sequence.
~Will
Old 10-19-2016, 05:33 PM
anothercolour anothercolour is offline
Show the pan automation lane on the track, and command-click on the control name.
Old 10-19-2016, 05:45 PM
Thank you. I knew it would be something simple like that. Strange it didn't show up in my web search.
Scott
Scott
Old 10-20-2016, 11:31 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Bring up the automation window. Command & numeric keypad 4
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 10-20-2016, 01:55 PM
amagras amagras is offline
Super useful, thanks!
(Ctrl+click on Windows)
amagrasmusic.com
Old 10-21-2016, 03:21 AM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Show pan automation lane, select all automation and delete.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 10-21-2016, 12:44 PM
fork-media fork-media is offline
put automation into preview mode. move pan to center. capture and write
no need to make selection - will write to whole length of project
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
HTML code is On
Undo not working when pasting automation to a different parameter johan2006 Pro Tools 12 0 12-15-2015 11:01 AM
Bringing up the same automation parameter for multiple tracks antonis Post - Surround - Video 7 05-01-2013 12:51 AM
Glide automation to current parameter chavernac Pro Tools 9 0 05-14-2011 05:16 AM
How to suspend a specific automation parameter ? Hanswurstlsepp ICON & C|24 6 08-13-2010 08:32 PM
Switching automation parameter views faster HearInc Tips & Tricks 5 08-04-2004 03:32 PM
