  #21
Old 07-29-2013, 12:07 AM
asterix2k10 asterix2k10 is offline
Default Re: Video Engine Problems with Pro Tools 11
I did a reformat and clean install of OS X Mountain Lion. Still doesn't work! I don't know what else to do.
  #22
Old 07-29-2013, 02:48 AM
mrhood mrhood is offline
I also did the same, to no avail. Had to use Logic instead.
Strange thing is that Drew Mazurek (on this forum) can get it to work with his 2008 Mac Pro (exactly the same as one of my machines).
  #23
Old 07-29-2013, 04:06 AM
Lightbulb Re: Video Engine Problems with Pro Tools 11
Please log this as a bug at protools.ideascale.com.
  #24
Old 07-30-2013, 11:59 AM
submitted:
http://protools.ideascale.com/a/dtd/...ng/110688-3779
  #25
Old 08-01-2013, 02:35 AM
It works now!
I upgraded to 32 GB RAM today (Crucial - used their system scanner to select the correct RAM for my system.) I also installed the latest EuControl software and hooked up an Avid Artist Mix and Transport. I just tried to open a session now with PT 11 HD and the video engine loaded this time. It took about 10-15 seconds.
I'm assuming the RAM upgrade fixed it?
If you're having the same problem, try installing the maximum amount of RAM your system can handle, using the Crucial system scanner to select the type.
  #26
Old 08-01-2013, 03:23 AM
I already had 32 GB ram, so I think a software change has made it work for you.
  #27
Old 08-01-2013, 02:36 PM
Or maybe it has something to do with me using an ethernet switch to hook up the control surfaces. According to Avid tech support, it's a network issue and not a RAM issue, so this is possible.
  #28
Old 08-26-2013, 01:05 PM
ssoutham ssoutham is offline
I had the same problem. I simply uninstalled Pro Tools 11 and then reinstalled it. It may have been because the first time I installed I only installed the drivers after or it could be because I tried to open a project that already had a video in it. After the reinstall I opened a blank post-production session and activated the video engine in the setup/playback engine menu and then closed the session and opened my preexisting video edit sessions and they worked.
  #29
Old 08-28-2013, 08:46 AM
Adman44 Adman44 is offline
I have the same problem with Pro Tools 11 HD on our Macbook Pro. Did you do a safe uninstall or a clean uninstall before reinstalling Pro Tools 11?
Macbook Pro i7, 17". Dell P-650, Mackie 1402/HR824/SR1530, 002R, TLM 103, Beyer TG-X60, SM58, AKG 112/C418's/C419, TPS II, Kurzweil ME-1, DM-Pro, Pod-XT, Fender Blues Jr.
  #30
Old 08-28-2013, 09:16 AM
I tried both ways... the problem persists. The "Waiting for the Video Engine to launch..." bar goes to the end and then sits. Any other ideas?
Pro Tools 10 Video Engine failed to initialize. GXTProductions Pro Tools 10 1 12-15-2013 12:54 PM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Pro Tools HD 8.01 Launching Video Engine fails? AMIEL Pro Tools TDM Systems (Mac) 3 10-25-2009 11:38 AM
Pro Tools 8 LE stalls at video engine launch Tommy Barth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2009 01:44 PM
Where's the Video Engine? admix Post - Surround - Video 4 05-02-2008 04:51 PM
