Problems with Pro Tools 8 LE Windows 7 64 bit
Hey guys,
I have pro tools 8.0.5 LE running on a windows 7 64-bit install, and I've been having 2 really annoying problems: First, when running pro tools I repeatedly get the message over and over again that I am running out of CPU power even though my machine has 8 cores and the total cpu usage as reported by pro tools doesn't even hit 65%. Also, in the settings I only have 6 cpus assigned to pro tools. Second, after a while of having my system on, I'll randomly stop hearing any sound. This includes system sounds, pro tools sounds, everything. I thought this was a driver issue, so I re-installed all my drivers. When that didn't work I re-installed pro tools as well. I'm still having the issue and don't know how to fix this. The only work around is to reboot everytime, but this is not a workable solution long term. Thanks. |
Re: Problems with Pro Tools 8 LE Windows 7 64 bit
Did you try setting number of cores to 7? PT seems to run better with odd number of cores, at least for me. How about a Sandra
Avid Windows 7 Optimizations Video Playlist - YouTube Windows 7 Optimizations and what Interface? Did you raise the buffer setting?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Yeah no matter how many cores I set it to, I always get the error. For interfaces I'm using the mbox pro. Took a look at the optimizations, but a lot of those don't really explain the issues I'm seeing. I believe the audio issue is definitely some sort of driver conflict. I usually leave the buffer set to 512. Honestly, if I can't get 20 tracks in pro tools with a limited number of plugins to run on an i7 processor, then something is seriously wrong.
SiSoftware Sandra
Computer Model : Gigabyte X58A-UD3R Processor Model : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz Speed : 2.83GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Gigabyte X58A-UD3R BIOS : Award (Phoenix) FA 04/20/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Total Memory : 6GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 540MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ATI Radeon HD 5700 Series (720 SM5.0 700MHz, 1GB DDR5 4.6GHz 128-bit, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 5700 Series (720 SM5.0 700MHz, 1GB DDR5 4.6GHz 128-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : ATI Radeon HD 5700 Series (720SP 700MHz, 1GB DDR5 4.6GHz 128-bit) STREAM Processor : ATI Radeon HD 5700 Series (720SP 9C 870MHz, 1GB DDR5 4.6GHz 128-bit) Storage Devices WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:) INTEL SSDSA2M080G2GC (80GB, SATA300, 2.5", SSD) : 75GB (C:) HL-DT-ST BD-RE WH10LS30 (SATA150, BD-RW, DVD+-RW, CD-RW, 4MB Cache) : 7GB (E:) TSSTcorp CDDVDW TS-H653Q (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices New Volume (D:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) System Reserved : 100MB (NTFS) Hard Disk (C:) : 74GB (NTFS) @ INTEL SSDSA2M080G2GC (80GB, SATA300, 2.5", SSD) 3.5" 1.44MB (A:) : N/A Pro Tools LE (E:) : 7GB (CDFS) @ HL-DT-ST BD-RE WH10LS30 (SATA150, BD-RW, DVD+-RW, CD-RW, 4MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW TS-H653Q (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : Pine Technology EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte 88SE91A3 SATA-600 Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon Inkjet iP4500 series (600x600, USB, Colour) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Also, after re-installing pro tools again. Every sound that plays through my computer sounds about a semitone lower and is slower as well. Not sure...where this is coming from.
Hey again,
I just re-installed pro tools, but didn't update to 8.0.5. The strange issues with the sound cutting off/being distorted and sounding lower have disappeared. There's definitely something in the 8.0.5 update that does not work on my machine. |
Considering you have a i7 that can't do 20 simple tracks I wouldn't overlook anything.
URBAN MUSIC- (Hip Hop and R&B) |
hey guys, any update on this?
I had that problem when my sample rate was set to 48 on my interface and 44.1 in pro tools
So many problems with Pro Tools SE on Windows 7 | steveuk | Pro Tools SE and Essential (Win) | 3 | 05-06-2012 03:46 PM |
Uninstalling problems Pro tools 7 on Windows 7 | rafflesia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-14-2011 08:57 AM |
Pro Tools LE 8.0.3 with Windows 7 Problems... | KittieKizu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-17-2010 12:13 PM |
Windows + Pro Tools= Problems! | matt2083 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 09:00 PM |
PRO TOOLS 5.1 ON A WINDOWS XP SYSTEM PROBLEMS. | hotcarl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-12-2003 02:54 PM |
