Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 06-30-2017, 12:40 PM
dez811 dez811 is offline
Default Appset
Is there a way to integrate an old appset with a new one? I have a lot of key commands and it would take me forever to do them over. I have commands that create a track, aux or master with the plugins inserted name ,notes ,bus ,amongst others. That would take forever to duplicate
Old 06-30-2017, 02:18 PM
EddieJones's Avatar
Default Re: Appset
I'm sorry, other than editing it with an xml editor there is currently no way.
Old 06-30-2017, 06:00 PM
crustn crustn is offline
Default Re: Appset
This is way overdue as well as copy/paste and duplicate.
Old 06-30-2017, 07:30 PM
Default Re: Appset
+1
Old 07-03-2017, 08:09 AM
Anthony_Anz Anthony_Anz is offline
Default Re: Appset
I agree an updated Appset Editor would be nice. It would be great to have a way of moving softkey assignments around so they can be re-arranged. an Import feature would be nice too. This way if an new appset is released we can import previously created softkeys.
Old 10-07-2017, 12:03 PM
koo_koo_bonkers koo_koo_bonkers is offline
Default Re: Appset
If you're not used to it, editing XML look like you're hacking into the Matrix. However the functionality you're asking for in the OP is possible editing the XML , you can run a 'diff' and manually choose what lines to replace/ merge. You can also very easily search the XML and once you get the hang of it should be very easy to do.
For example >> https://www.devart.com/codecompare/
Just wanted to provide that option if you were not already aware. I'm also looking to manage Appset files more effectively across multiple work stations in a multi seat environment. I can see the appeal for Avid to provide this feature in the EuControl app but honestly it may be more flexible to edit the XML directly. Hope this helps ..
MacPro 5,1 - 2 x 2.66 6 core - 32G Ram - SSD's - Mac OSX 10.12.6 - HD Native Card - Omni - Focusrite RedNet 5 - Avid Dock - iPad2
