Old 11-18-2010, 10:04 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: 6.4.1 TDM G4 Tiger
I seem to remember there being problems with NVIDIA cards from that era. Can't remember the specifics, but I always tried to stick with G4's that had ATI cards.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 11-19-2010, 12:01 PM
Siegfried Meier Siegfried Meier is offline
Ya, this one is an ATI, so not sure what is up. I'll swap out another one to see if it fixes it. Only happens through the KVM though, direct connection is good. Definitely not the KVM as it's worked for years, and continues to work on other computers.
OK, so I installed 6.4.1 CS4 this morning, and my non-playing back action is back again. What an effin' piss off. Means I have to reinstall the entire operating system from scratch again, as when I tried to roll back the problem continues to exist. This will only be the 7th time I've done it now.
These old systems are hardly worth even maintaining. Nothing but problems.
Old 11-19-2010, 12:41 PM
Ugh. Reinstalled 10.3 with just 6.4 TDM, and the problem still exists...
I'm about to completely lose my mind...something must be defective. The MIX card, the Mac, something is totally screwed.
Old 11-19-2010, 12:55 PM
Ok....kinda got it working again. At least I get playback, but now on an audio track I see level...for no reason. No input, no plugs. Bursts of noise of some kind that show up on the track meter as well as the 888 meter. Panning a mono track hard left will still show this level as 1-2 on the 888.
Very weird...and getting weirder by the minute...
Old 11-19-2010, 06:45 PM
You have a bad 888 or a bad mix card for sure. That is not normal behavior.
- John
  #16
Old 11-19-2010, 08:54 PM
Yup, this is what I've determined. The 888 was in storage for a few years, but worked wonderfully before then. The MIX core card is new (used), and it's my guess that it's a faulty card, regardless of what Digitest is telling me.
Bummer. So much time wasted...
  #17
Old 11-19-2010, 11:18 PM
Alright, so I thought I'd try this one last time, and I played a 44.1 WAV file through Quicktime and using Coreaudio. It plays fine...audio output on 1-2 only, but at least it confirms that the 888 is working correctly, yes?
So, with Digitest passing the card, and the 888|16 seemingly working, there must be still something wrong with the Core card, yes? Perhaps when the actual DSP chips become active it all goes south. When I just tried to play audio out of Pro Tools again it was all distorted and messed up. After quitting, going to Quicktime, it played fine again.
Thanks,
Sig
  #18
Old 11-20-2010, 12:56 AM
digitest doesn't necessarily guarantee a card is good. I've seen bad cards pass, and good cards fail(or at least I couldn't find anything wrong with them).
One thing about 888's too is they get hot, especially when audio is passing through them. so it could be that when the 888 get's enough activity that the heat triggers your problem.
If I were to guess though, I'd say it's the card. mdd G4's run hot to begin with, and are notorious for power supply problems. so adding a hot card that puts more strain on the power supply could be enough to mess things up.
- John
  #19
Old 11-20-2010, 08:14 AM
milesofwire milesofwire is offline
If that Mix card turns out bad can I have it to try to repair?
raceboat( at )pacbell( dot )net
  #20
Old 11-21-2010, 11:45 AM
kurt's Avatar
kurt kurt is offline
You are of coarse trashing all digi prefs before any new try?
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
HTML code is On
10.4.8 (Tiger) Security Update 2009-005 (Tiger Intel) Help Brushfire Pro Tools TDM Systems (Mac) 1 11-25-2009 09:16 PM
Tiger and PT7 Icabod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2005 03:51 PM
001 on Tiger MrMaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-29-2005 10:27 PM
proper panther to tiger with clean tiger install doug_hti Pro Tools TDM Systems (Mac) 21 07-10-2005 05:00 PM
Tech Question---M-box and tiger TDM & tiger Kawi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-17-2005 03:31 PM
