Old 06-10-2008, 06:54 AM
jongilbertson jongilbertson is offline
Default USB MIDI device connection - Mac Audio MIDI Setup
I have connected an Akai MPD32 to my Mac using the USB interface. It's going to control the BFD2 plugin. I just tried out the standalone BFD2 using the MPD32 and it is working great with the included BFD preset mapping. So now taking the next step to setup in PT.
On the Mac Audio MIDI Setup, the MPD32 device shows up as a driver created device, but it doesn't allow me to connect it to anything. It's got the connectors on the bottom of the icon, so it has the appearance of a MIDI interface rather than a device. Since it is physically connected to my computer with USB, do I need to draw any connection as would be done with the 5-pin MIDI cable? Or is this indicating some problem?
I'm forging ahead with setting up my session with BFD2. I figure there is some plug-n-play magic to the USB that I don't understand yet. And I can always resort to the traditional 5-pin cable if there is a problem.
Thanks for any help you can provide!
Old 06-10-2008, 07:38 AM
DigiTechSupt's Avatar
Default Re: USB MIDI device connection - Mac Audio MIDI Setup
No, there's no need to connect anything to or from the Akai. It will just show up as an available input on a MIDI or Instrument track. You don't even need to necessarily select it specifically in Pro Tools, since Pro Tools defaults to 'All' for MIDI input, it will accept MIDI data from any device currently connected and route it to the selected output.
Avid Audio Tech Support
Support FAQ
Old 06-11-2008, 10:13 PM
Thank you! I hadn't been able to get back to it until tonight. I've got separate Aux tracks assigned for each BFD2 kit piece and room mics, and successfully controlling BFD2 from the Akai MPD32 via USB MIDI. I'm not sure I follow how the USB is providing the MIDI, but I'll save that lesson for another day.
Now for some recording!
Audio MIDI setup says DIGI 002 midi device is offline oliarnalds MIDI 17 10-23-2016 10:13 PM
MIDI Setup - Not seeing USB Audio Device as an Input Port Option oldtracy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-15-2013 09:22 PM
Need Help badly, erased Midi connection in Midi Setup Bongo38 Pro Tools M-Powered (Mac) 2 10-08-2007 06:05 AM
Audio Midi Setup can't locate my device rockwithrespect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-15-2004 11:03 AM
Adding new MIDI device to AMS setup? (new, as in one that is not there) Spyder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-30-2003 03:55 PM
