Blank "Sign in Window" PT First
Hi all,
after waiting a looong time i've finally downloaded Pro Tools first. Only i have a small problem when starting the application. It requests me to Sign in, when i click this button a popup appears, this popup however is completely blank.. So i cannot fil in any account details... Anyone else experiencing this problem and have found a workaround? Firewall is turned off btw |
Re: Blank "Sign in Window" PT First
Only one other report I could find, and it was their firewall preventing the sign in page from loading. Any anti-virus protection installed, or firewall in a router possibly?
• linkedin •
No anti virus and no firewall, also tried via a hotspot of my phone, unfortunately no result, any other idea's?
btw, where dit you found that other report, maybe there a solution was found?
Cheers! |
So I see that problem is still not solved?
I have exactly the same on my Windows7 machine. Unfortunately now I see that it's probably first of many many other problems that I will have to handle here :/ |
I just downloaded PT yesterday and have been having the same issue. I've uninstalled and reinstalled multiple times without any success. Any help with this would be much appreciated.
My problem is solved. Looks like it was my firewall. I closed pro tools first, went to my firewall and disabled it. Went back to pro tools first, launched it and it signed me in automatically. If anyone else is having this problem try checking your firewall. You can always temp disable it and turn it back on later.
My next issue is....HOW DO I USE THIS! It's so much to learn. Cheers! |
It doesn't seem to be firewall or any addblocker that was enabled. Note that I'm working on a mac.
Hoped that the 12.2.1 version would have taken care of it, unfortunately it hasn't. Any one of you had succes with a different strategy? |
I have the same problem. Disabled my firewall and still no luck. Closing the signin windows and then trying to sign in from within ProTools brings up a 'you must be connected to the internet' message, even though I clearly have internet access! I'm running Windows 10 64 bit.
One thing that comes to mind is that I have 2 monitors.....I wonder if that may be confusing ProTools somehow? Anyway, nothing has fixed the problem so far, so I hope someone can come up with an answer or it looks like ProTools won't be getting much use on my PC! |
Edit window blank | jeff5x0 | Eleven Rack | 2 | 06-27-2013 10:41 AM |
Blank Markers Window | corTools | General Discussion | 2 | 12-15-2003 10:21 AM |
Blank AudioSuite Window | Rob Macomber | Pro Tools TDM Systems (Mac) | 6 | 11-13-2003 06:52 PM |
RTAS window is blank | Willmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-02-2003 02:08 AM |
Help! Blank start up window on 5.1.1 | Petermix | Pro Tools TDM Systems (Mac) | 0 | 09-03-2002 10:55 AM |
