Pro Tools 10 / MBox Mini I/O Configuration
Hello,
I am running Pro Tools 10.3.2 (Student Version) through an MBox Mini (3rd gen) on Windows 8. While installation and hardware/software setup wasn't easy, I managed to figure out how to get most of everything to work (install/run software/drivers in Windows 7 Compatibility mode, run as admin). The only problem I'm having at this point is that Pro Tools doesn't recognize the MBox as an I/O interface and I have no clue how to designate the MBox as an I/O so that I can start recording solo projects at home. When I attempt to select an I/O, my only options that show up are:
Pro Tools seems to work fine, it recognizes the MBox as the Playback Engine correctly, but I can't figure out how to designate the I/O of the MBox for use with Pro Tools. The MBox appears in the I/O setup menu under column A for both Input and Output tabs, but in the Mix window, it simply does not appear as a selectable I/O for any channel. I hope someone can help me figure this out. I can give computer specs if requested, but I don't think its highly relevant at this point since Pro Tools works fine. TL;DR - MBox Mini doesn't appear as a selectable I/O interface for any channel on Pro Tools 10, but works as the playback engine just fine. |
Re: Pro Tools 10 / MBox Mini I/O Configuration
The Mbox needs to be selected in the Setup>Hardware window; Audio Engine selection. Right now your motherboard's audio is the selected engine(or ASIO4ALL if you have that installed).
I am having the same problems. The input tab has no way to select new pathways, delete paths or restore default. I uninstalled pro tools and reinstalled.
and I have my interface selected in setup, playback engine and for the sounds on my mac. It's just not recognizing any inputs in pro tools. Please help, this is very frustrating. I don't know if its pro tools or the focus rite interface Below is a picture showing my problem |
You've managed to resurrect a thread from 2013 - and one that doesn't even relate to your particular interface. Plus you're in the Windows forum
A quick search turned this information up. It appears to be a problem with the Focusrite drivers.
Pro Tools 8 LE with MBox Mini | CyberWrek | Getting Started | 0 | 09-27-2013 02:50 PM |
mBox Mini and Pro Tools 10 | WernerF | Pro Tools 10 | 8 | 07-20-2012 11:36 PM |
My first day with mBox 2 Mini/Pro Tools 8 Le | eliezering | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-07-2012 04:47 AM |
Mbox Mini with Pro Tools 10.. Help me! | cadetkev | Windows | 6 | 01-11-2012 06:30 PM |
Mac OS X 10.6.7 MBox 2 Mini Pro tools 7.4 | xtoller | macOS | 2 | 05-28-2011 10:49 PM |
