Old 11-29-2002, 06:24 PM
peter parker peter parker is offline
Default * SPEED plugin - quick question on pitch control
ok, lets say i just want to change the beat, so i go to "CALCULATOR mode" and i adjust the Tempo to what i want it to be. easy.
i just want to adjust the tempo, not the pitch.....
ok, but i look over to my right to the Key info and it always defaults as "C" in the "original", and "modified" slots, and in the "change" slot it reads "0". i take it that this should not change the pitch from its original state ..... since it says "0" change.......but why does it default to "C"???
does the original beat actually change to "C" once processed through speed? what if the beat or vocals were not in "C" to begin with......should i change anything ?? am i actually changing the pitch by leaving it in this "C" default stage?
what do you guys make of this?
[img]images/icons/smile.gif[/img]
Old 11-29-2002, 08:23 PM
J. FO J. FO is offline
Default Re: * SPEED plugin - quick question on pitch control
don't worry about it. non-destructive editing is a blessing of hd editing. "c" is a reference pitch. leave it at 0.
Jeremy Forbis
Old 11-30-2002, 11:05 AM
ok cool, thanks.
so when it defaults at "c" , i should just leave it at c. i was worried that it actually changes the pitch to c automatically....even if it wasnt supposed to be in C....so the C key is actually like a nuetral setting so there will be no change in pitch from the original sample with the C default. right? thanks again.
pitch 'n' time/SPEED question keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-24-2006 10:38 AM
Just a quick question about external plugin cards fabpab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-28-2005 03:37 PM
Serato - Pitch N Time (Quick Question) jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-19-2004 07:41 AM
Serato Pitch N Ttime (Quick Question) jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-13-2004 09:00 AM
Quick Reason question on pitch... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-26-2003 10:45 AM
