Old 04-11-2012, 04:38 AM
dannydog dannydog is offline
Default Importing Newer sessions into older versions
Hi guys. Currently at the studio where I work they are using Pro toolsV8. I have recently purchased an old mbox which is running v6.4.4. I want to do some editing at home and until my upgrade arrives (v8) I am stuck with using v6.4.4.
However when i try and open the session that was recorded on v8 I am given the error message that "this is not a pro file" file extension ls a ptf ext file."hmmm
Any help would be great.
Thanks Gary
Old 04-11-2012, 04:44 AM
Default Re: Importing Newer sessions into older versions
i believe this to be the answer?
sessions done on PT7 or 8 will not open in older versions unless they are saved as 6.x compatible. I would find someone with a PT8 setup and have them open the sessions and then re-save as 6.x compatible
Old 04-11-2012, 09:56 AM
JMS40 JMS40 is offline
In version 8, when saving a copy of the session, you have options in the file format drop down menu to save for previous versions of Pro Tools.
The choices are:
Windows:
• Pro Tools Session (.ptf); supports Pro Tools
7.x -> 8.0.
• Pro Tools 5.1 -> 6.9 Session (.pts);
• Pro Tools 5.0 Session (.pt5)
Old 04-12-2012, 05:33 AM
Thank you for you're reply JSM40
Can newer PTLE always process older PTLE sessions? Earl D Windows 3 02-25-2014 12:02 PM
Importing PT Sessions from other PT versions lukerfoley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-25-2009 04:20 PM
Opening HD 7.4.2 Sessions on Older Versions Lumin Pro Tools TDM Systems (Mac) 2 10-30-2008 02:13 PM
Importing sessions from different Pro Tools versions SteveGarman Pro Tools TDM Systems (Mac) 1 04-23-2008 04:37 PM
converting pt 7 sessions to older versions mr. clockwork 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-18-2006 12:12 AM
