Old 09-29-2009, 03:50 PM
whitelabellt whitelabellt is offline
Default Apple Partition, Master Boot, GUID??????
So I need to format my external hard drive to work for both at home and at school. At home I have an intel based Macbook Pro and a PC with XP and at school we use PowerPC Mac.
I know that the school Macs don't work with GUID Partition, but do with Apple Partition, sooo how should I format this drive to work on all three computers?
Old 09-29-2009, 03:54 PM
Craig F Craig F is offline
Default Re: Apple Partition, Master Boot, GUID??????
HFS+ and install the HFS Firewire access option from your PT install disk
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 09-29-2009, 04:29 PM
The Dougfather The Dougfather is offline
I think the partition map is only an issue if you want to boot from the drive not read and write to it.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 09-29-2009, 04:34 PM
JoyMODE101 JoyMODE101 is offline
i think he's referring to the PARTITION MAP SCHEME
his hard drive is already formatted as Mac OS Extended (Journaled)
i'm having the same reservations as well
hey admin,
if we were to use the Apple Partition Map scheme, would it also work on a PC using Vista??
thanx!
Old 09-29-2009, 05:14 PM
zodo zodo is offline
On PPC machines, Pro Tools is unable to write to any drive formatted with the GUID partition map scheme. It doesn't just apply to booting, unfortunately.
Format the drive as APM, and Mac OS Extended (Journaled). You'll need to have HFS+ support (optional in the PT installer) on the PC, but you shouldn't have any problems if that is the case.
Old 09-29-2009, 08:39 PM
sounds good
but hey
so... what would be the reason for someone formatting the drive using Master Boot Record?
when i formatted my new external hd, i just reformatted it using mac extended journaled, not really paying attention to the partition map scheme
it turns out it got formatted using Master Boot Record
the external hd works on a ppc mac, intel mac, and my pc with vista (the hfs+ drivers were installed, of course)
should i reformat my drive using Apple Partition Map and installing the hfs+ drivers?
i understand that "hey, it already works on the 3 different computers ure using, so just leave it as it is", but... i don't know... maybe it also works if
i reformat my drive using Apple Partition Map instead (while using the hfs+ drivers).
or... would it still work on a vista pc if all i did was format it as Master Boot Record and NOT install the HFS+ drivers?
am i already using the nominal method of getting my hard drive to work on ppc, intel mac, and vista?
if not... what IS the recommended way to do this?
Old 09-30-2009, 07:37 PM
Hey man thanks a lot!!! I formatted the drive with APM and Mac OS Extended (Journaled), tested it both at home and at school, and its working good.
Thanks again.
Old 10-01-2009, 12:29 AM
is there a drawback to using the Master Boot Record scheme instead of the APM scheme?
what's the difference?
Old 10-01-2009, 12:34 AM
JazzyJ JazzyJ is offline
You can format it as NFTS for Win XP and then install 'PARAGON' on the MAC:
http://www.paragon-software.com/home/ntfs-mac/
to make it work in OSX
or
Format it on the MAC and use 'Media 4 Mac Drive':
http://www.mediafour.com/products/macdrive/
so that you can read it on the PC.
However as someone suggested, PT7 has the equivalent Media 4 drivers included so that a PC will read the drive.
Good luck
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
GUID or Master Boot Record? JoyMODE101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-05-2011 06:29 AM
GUID vs. APM partition scheme question jeremyroberts Pro Tools TDM Systems (Mac) 11 11-04-2010 02:11 PM
GUID Partition vs Apple Partition Mount Royal Pro Tools TDM Systems (Mac) 2 08-18-2010 07:20 AM
Audio Partition and Boot Camp Partition trouble MboxToo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-15-2009 07:35 AM
Dual boot partition for laptop with Win2000 j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 12:25 AM
