Old 08-03-2009, 02:37 AM
bugnut bugnut is offline
Default MIDI Piano Roll "Greys Out"
Hi. I am trying to do some stuff with MIDI which I haven't done a lot of and I keep running into a problem where the piano roll "greys out" and doesn't trigger the VSTi. It almost looks as though the track has been de-activated but it has NOT. The controls on the left side of the track are NOT greyed out. Everything works fine then it doesn't. Any suggestions?
http://www.bugnutrecords.com
Old 08-03-2009, 05:51 PM
Default Re: MIDI Piano Roll "Greys Out"
Is the MIDI Output Assignment valid? Corresponds with the Plug-in you are using? Also try re-inserting.
filosofem
Old 08-03-2009, 07:51 PM
Fastermouse Fastermouse is offline
I have run into this too. If I delete the track and open another, the exact same method, it will be fine. HUH?
I will hit ctrl+shift+N Dialog opens start stereo or mono inst track and it will be greyed out. Try putting a VI on it and my controlers won't recognize it and it stays greyed. Then if I delete the track and start over it usually will be fine.
Old 08-03-2009, 09:15 PM
the assignments are pretty straight-forward. i'm just using xpand and hybrid. right now i can't even create a new instrument track without it being greyed out...also when i import a midi file all the midi tracks are greyed out. is this one of the reasons why everyone makes fun of pro tools' midi implementation?
Old 08-03-2009, 09:35 PM
problem solved...use reason instead!
Old 08-04-2009, 04:13 AM
danander11 danander11 is offline
It may still happen.. I and a few others have had this issue. The workaround that we have used is to mve the VI from one insert slot to nother, and sometimes back again. MOST of the time that works, but not always. Sometimes I've had to create another track and movethe notes/VI to there for it to work.
Good luck
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 08-04-2009, 05:43 PM
Try trashing the DAE and Pro Tools Preferences.
filosofem
Old 08-05-2009, 12:24 AM
filosofem
I literally did this at 1pm and had the problem at 2pm.
Old 08-05-2009, 08:10 PM
What version of Pro Tools are you guys running? Third party plug-ins?
filosofem
Old 08-05-2009, 08:40 PM
filosofem
PTLE 8.0 cs3
Waves mercury and studio classics v 6.1.(whatever the latest is)
dB112 Redline Reverb.. (problems happened before I installed this one)
MPTK2
Digi plugs, a couple, all current.
Massey a couple, all updated.
Dedicated PT quad pc
Digi 003r
and a three year old that likes to help me push buttons
Here I am,
Hobo Shave!
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
Anyone ever heard of the "Simply Music" piano teaching method? Top Jimmy General Discussion 0 09-02-2011 08:37 PM
Help requested: Unwanted "Pre-Roll" video problem! DanButsu Pro Tools M-Powered (Mac) 1 04-15-2011 07:44 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
I don't know how to use "Post-Roll"... can anyone teach me, please? Wnna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-04-2002 02:48 PM
